Question about Kenmore 62602 Electric Dryer
Kemore Dryer will not start
I have a Kenmore Ultra Fabric Care electric dryer, model # 96284800, it was purchased in 1988. First it would not stop when I opened the door; then it started making a funny noise for the first 60 seconds of drying - that would stop and it would dry the clothes just fine so I cleaned out the vent really well with a vacuum, it cut off as it was supposed to, but still made the funny noise for the first 60 seconds of drying, then one day it stopped in th middle of a load I was drying and it will not come back on
  • 291 Answers
I would check the voltage and the dryer where cord attaches to dry to make sure you havt 220volts... check you door switch... also you have a thermofuse in back .. check for burn off wires or lose wires.. make sure dryer is unplugged... the thermal fuse with be white plastic oval in shape on the blower venting with 2 wires.. here is a pic if it uploads
Posted on Sep 05, 2007
  • 625 Answers
The dryer is almost 15 years old! the drum rotates on two or three felt bearings in front and a ball bearing in the rear. the belt may have broken, the tensioner may have loosened. the motor goes in one direction only and starts off a centrifugal start switch. If the motor doesn't get up to speed to open the start winding, the machine just won't go. check the belt first.
SOURCE:
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Kenmore Ultra Fabric Care dryer Model/stock number 96595220 65952 Dryer shuts off all the time. Runs, heats, works, then just stops. This happens repeatedly. Please help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 659 Electric Dryer
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Vic
Jun 25, 2009 | Kenmore 659 Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore Electric Dryer
check your fuses.one runs the dryer and other heat the dryer.
check to see if belt is broke or wire is burned off of motor.
Mar 08, 2008 | Dryers
just look at you local paper for a nice working dryer i get 125.00 each with a 30 day warranty with out warranty about 50-75 depending on condition start with your local paper and see what they are going for
Dec 28, 2007 | Kenmore 659 Electric Dryer
Kenmore ultra fabric care
only thing i can think of without being there and able to test parts is your door catch could be faulty
Aug 10, 2007 | Kenmore 659 Electric Dryer
Kenmore 62602 Electric Dryer Logo
215 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
