Kenmore 106.53082300 - About 4 weeks ago icemaker stopped working, except intermittently. Inlet tube not froze up nor is tray.
Probably unrelated.....
Now refrig and freezer have stopped cooling and there is a ''pop'' or ''click'' about every 5 minutes. Sounds like a switch may be trying to turn something on. Airways between the compartments seem to be set correctly and open. There's no frozen up condition at the back of the freezer.
Sounds like you need a new relay for the compressor. Unplug from wall and check the compressor see if realy that is attached to pins on compressor, is burnt.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kenmore 53082 / 53084 Side by
ice maker will not dispense ice thur door after taking apart! I feel like something was not lined up...
(More)
ice maker will not dispense ice thur door after taking apart! I feel like something was not lined up properly,motor runs but auger not moving darrelledd@yahoo.com Ice maker will not makeice
kenmore model # 59658642890
My freezer is currently at 0 degrees and the refrigerator at 35. However, every- so-often the motor...
(More)
My freezer is currently at 0 degrees and the refrigerator at 35. However, every- so-often the motor stops and the freezer rises to 40+, ice melts, etc. Not the normal defrost. After a while it kicks on back on. I've had the condensor and the defrost heater replaced to the tune of over $500. The repairman can't think of anything else. Any ideas?
ice maker works perfect but water dispenser does'nt work and i can't figure out how to get the...
(More)
ICE MAKER WORKS PERFECT BUT WATER DISPENSER DOES'NT WORK AND I CAN'T FIGURE OUT HOW TO GET THE PLASTIC COVER OFF TO CHECK IT OUT
we have a side by side refridgerator, its leaking water BAD..... water is leaking from the water/...
(More)
we have a side by side refridgerator, its leaking water BAD..... water is leaking from the water/ ice dispenser now its from the bottom of the fridge part too... how do i solve this problem or how do i disconnect the water...
