Question about Brother IntelliFAX 2800 Laser Fax
Brother fax 2800
Won't turn on......checked phone lines, check outlet - everything is ok. wondering is there an on and off switch? i have unplugged it, moved it, nothing.
  • denny410 Dec 17, 2007
    Where is the fuse?
  • 163 Answers
Check the fuse,rectifiers in the power supply board of your fax machine
Posted on Sep 21, 2007
SOURCE:
Brother 4100 - can't send fax's - get busy notice
unplug machine, press and hold the "stop/clear" key and while holding key down, plug machine back in and continue to hold the button for 5 seconds. that should take care of problem.
hth,
razors
Jun 30, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 1840 bleeps
Try to unplug the handset and try again.
Unplug the phone cords from any shared devices.
Do you have DSL or any other digital type phone line?
Make sure the phone cord is plugged into the LINE port of the fax machine.
Jul 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Brother lntellifax 2800
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
Jun 23, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intelli fax 2800
It could be that your sending fax is sending paper not facing the scanner. In that case tell them to turn the paper over to send. Other than that, it could be that the telephone lines are so dirty that the fax protocl fails at the check frame signal. You will have to adjust the equalisation and line attenuation. Don't count on the telephone company to help you, they always want you to do everything 1st before they will admit to any fault on their part.
May 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 --message turn off and call Brother
what you want to do is unplug for a couple of minutes while checking to make sure there is paper jammed anywhere in the machine, remove all your paper from supply as well. then time how long it take to warm up or the error code comes up.
mikey
Mar 13, 2008 | Brother IntelliFAX 2800 Laser Fax
Audible ring has changed/machine won't answer when called
It is to do with "smart ring" feature or in your area called "distinctive ring" feature. The machine won't receive unless the ring pattern matches your distinctive ring pattern. If you are not using that feature, then you must turn the feature off. Then set your receive mode to "fax tel" mode if it is your only line.
Jan 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother 2800 fax
Make sure you have the telephone cord plugged into the jack marked "line"
Nov 06, 2007 | Brother IntelliFAX 2800 Laser Fax
The brother Intellifax 2800 intercepts other faxes
Make sure that the proper phone number is installed in the fax.Also that they are not sharing the same common line.
Oct 17, 2007 | Brother IntelliFAX 2800 Laser Fax
Stuck in print mode.
please check the telephone line may be not giving complete tone if telephone line is OK then there is the fault in the electronic board
Sep 20, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
53 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
