Question about Siemens Gigaset 8825 Cordless Phone
Siemens 8825 gigset 2 line phone
Cannot get the mobile stations to make any connection with base station. Searching is blinking in the screens. Power is on to both mobiles. both blink serching cannot figure out how to coordinate they do not ring nor do they have dial tones. Base station seems to work on both lines
  • Anonymous Mar 28, 2014
    Have checked for messages and there are none. Yet red light continues to blink. How am I able to get rid of the blinking light.
    Novelist:
  • 106 Answers
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Posted on Feb 11, 2008
SOURCE:
My handset for a Siemens gigaset 8825 keeps saying searching. How can I fix it?
The base station must be defective or unplugged form the wall socket or phone jack.
Nov 18, 2016 | Siemens Lands Phones
Display keeps saying 'searching'
I don't have this model but I have had two Siemens phone systems. Typically, when the handset says "Searching" it is trying to connect to the base station (the part actually connected to the phone line). This can happen if the handset is too far from the base station to connect to it wirelessly. It can also happen if the handset has become unregistered from the base station (or was never registered to begin with). If the distance issue is not the problem, look in your documentation for how to register the handset and give that a try.
Sep 07, 2014 | Siemens Gigaset 4215 Cordless Phone
The lights on the base station are not working. Yes, I have checked the owners manual.
The power supply of the base station is working correct? the cable from the power supply is not broken? and the cable from the power supply is inserted?
Just a few questions, things I would start with when my base station wold not have any lights.
Oops the base station of my Siemens Gigaset S79H does not have lights.
Jul 22, 2014 | Siemens Gigaset 8825 Cordless Phone
Siemans Gigaset 8825 BaseStation
Is the line blocked in settings at the base? This would be the only solution I can think of - hope it helps!
Dec 01, 2008 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Sep 15, 2008 | Siemens Gigaset 8825 Cordless Phone
LCD display screen replacement for Siemens 8825 phone base
Yes we have new ones we sell to the do it yourselfers or you can send it in for repair and we do some updating and put in a new display. You can find us by googling Siemens cordless telephone repair and look at the non-sponsored links.
May 30, 2008 | Siemens Gigaset 8825 Cordless Phone
Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Apr 18, 2008 | Siemens Gigaset 8825 Cordless Phone
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
I need reset pin number
To reset your pin on your base station, you push Menu, scroll to System Settings, DON'T PUSH SELECT, push * 6 5 # That will reset the pin.
Aug 17, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
463 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
