Question about NEC MultiSync LCD1700M (White) 17 in. Flat Panel LCD Monitor
LCD monitor keep on flashing/blinking
The LCD monitor keeps on Flashing/Blinking. The connection with the CPU is OK. I can see the Window screen between the flash. It is working OK with other monitor. Can somebody hepl me. I have already unscrewed the monitor and I don't see any capicitor burn out
0 characters
1 Points
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
Sep 03, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
My acer lcd monitor has no display and the power button keeps blinking. is there a way to fix this myself.
that may be the problem of cpu disconnect the signal cable and observe the massage that "no signal check the signal cable "if that massege appears then monitor is ok problem lies in the cpu
Mar 15, 2010 | Acer AL1511 15" LCD Monitor
Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power lcd green light keep blinking. Any solution? thx
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Feb 01, 2010 | HP L1906 19" LCD Monitor
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Acer AL1511 LED light keep blinking
Check the Data card which connect from monitor to CPU Video adoptor
Aug 21, 2009 | Acer AL1511 15" LCD Monitor
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
NEC mutisync LCD 1700m Flashing/Blinking
You have an intermittent problem. That means a component is going bad in all probability. If it was a capacitor that burned up you would not have any picture. Your problem requires a schematic plus an tester. You would need to check values for all components. If you have not done this (and assuming you can follow an electrical schematic) and if new to diagnosing these types of problems plan on spending many hours at the task. The question you need to ask yourself perhaps is is it worth it.....particularly since even if you find the problem it may require ordering parts...and you might need some basic soldering skills, etc.....If it was me...I would probably either send it in for repair (deifnitely if under warranty) or buy another.
Aug 29, 2007 | Dell E176FP 17" LCD Monitor
NEC MultiSync LCD1700M (White) 17 in. Flat Panel LCD Monitor Logo
35 people viewed this question
Top NEC Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a NEC Computer Monitor Expert? Answer questions, earn points and help others
