Question about Sharp CD-BA150 Shelf System
Mini sharp stereo
Cd reads but disk tray keep going around when you press play.what could be the cause would appreaciate if you could reply?
  • 82 Answers
Try pressing the play button on the remote. If it works correctly, the play button on the unit may be defective.
Posted on Mar 27, 2008
SOURCE:
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
I have a Sharp CD-DK891N Mini System. The 5 tray CD system will not play any CD's, there isn't anything stuck in any of the trays. How do I get the CD 's to play??? Any help would be appre
Get a CD cleaning kit and follow instructions, if no change the laser pickup assembly will need to be replaced, far cheaper to buy a new player.
May 12, 2012 | Sharp Audio Players & Recorders
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Dan
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
My ps2 game disc says disc read error, but there is nothing wrong with the disc
Most disk read errors that are not caused by the disk itself are caused by having a dirty lens in the drive you put that disk into.
Two easy ways to clean that lens are either buying a cd lens cleaner (cd with brushes on the underside of it) or by using a can of compressed air to blow the debris off the lens.
If you go the route of compressed air in a can, there is an extension that comes with the can...it usually looks like a mini red sipping straw. You can reach the lens by open up the drive tray and pulling the power to the console when it is open. The reason to pull the power is that you can now move the tray halfway closed without it auto closing on you. When you have access to the lens from positioning the tray, stick the extension into your console and place it right at the lens and press the nozzle to spray the air. Do this a couple times and try reading your disk again.
Hope this helped.
Sep 14, 2009 | Sony God of War for PlayStation 2
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
Sony mini hi fi shelf system reads no disk
you may have a defective lense . but check your disc to see if they are dirty..
Jan 06, 2008 | RCA RS2505 CD Shelf System
Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Dec 15, 2007 | Sharp CD-BA200 CD Shelf System
Cd cleaning disc is not advisable to clean your laser lens.. all you have to do is manually cleaning method! open the unit go to laser lens and clean it with 100% cotton buds then rub it slightly clockwise, but careful this is sensitive parts.
Sep 26, 2007 | Sharp XL-MP130 CD Shelf System
112 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
