Question about Motorola Mobility RAZR V3c Cellular Phone
Changing the faace plate
I would like to change the face plate on my Razor 3. can you tell me how it is done?
  • Anonymous Sep 05, 2007
    no one has let me knoe if thet know how it is done
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
I'd be very careful about disassembling your phone. At a minimum you have voided your warranty by doing so. You could also damage the operation of the phone by trying to open it up. My advise is to use the vinyl covers unless you are totally willing to risk writing off your phone and needing to buy a new one. There are ways of corse but it involves taking off hinges and cutting the new frame. Overall it is NOT worth voiding your warranty and stuff
Posted on Sep 07, 2007
  • 1 more comment
  • Anonymous Sep 12, 2007
    ok i will send directions but please reconsider.
    1. Remove The battery.
    2. Remove the 4 small rubber flip-door bumpers that cover the screws.
    3. Unscrew all 4 screws using the T4 screwdriver.
    4. Use Panel Tool to lift up the FacePlate.
    5. Use the Panel Tool to lift up around the edges of the FacePlate
    on the left and right side. Then lift the bottom of the FacePlate.
    Also remove the chrome buttons and remember the postions.
    http://www.gyvergear.com/PayPal/Razor/fa...
    One of the favorite and most requested modifications for cell phones is for changing or installing a new faceplate on the Motorola V3 RAZR mobile. Sometimes called a case or a skin of the cell phone, it is a great way to show your own personal style after you have that RAZR cell phone. This guide will explain to you the installation process for how you can replace the face plate on your Motorola V3 RAZR.
    The first is that you will need a specific precision screwdriver, a TORX T5 ? looks like a star. You can generally get them from your local hardware store, or in the worst case get them from eBay. Secondly, and most obviously ? you need the faceplate that you want to replace. If you have these, then you are ready to go!
    Here is the step by step installation manual.
    1. Turn off your Motorola V3 RAZR and remove the battery. You will be opening up the case and you want to make sure there is no power to your phone as you are dealing with electronic components.
    2. Flip open your Motorola V3 RAZR. At the four corners of the screen there are rubber screw covers that you will need to remove to expose the screws. You might be able to use your fingers, otherwise use a precision flat head screwdriver. The rubber covers at the top of the LCD screen are larger than those at the bottom ? make sure to keep them separate.
    3. Using the TORX T5 screwdriver, loosen and remove the screws at each corner of the screen. There is no specific order you need to be concerned about.
    4. There are 6 clips that hold the faceplate to your mobile phone, to at the top, two in the middle, and two at the bottom. Start with the clips at the bottom (where the phone pivots or flips) and work those loose (flat screwdriver may be helpful). Then work the middle two, and then the top two should come off easily. Be very patient, this can be a difficult task.
    5. Snap on your new faceplate and secure all 6 clips to insure the faceplate is properly installed.
    6. Install the screws and lightly tighten.
    7. Replace the rubber screw covers.
    Congratulations, you have completed the step-by-step tutorial successfully and now your new Motorola V3 RAZR (V3i, V3m, V3c) faceplate is installed!
    Hope this helps Better found two different solutions. If it does please adjust the rating.
SOURCE:
Need to unlock Motorola Razor V3xx to change from Cingular to work on Verizon
See response here: Need to unlock Motorola Razor V3xx cingular to work on Verizon
Mark
Motorola Support
Apr 12, 2014 | Motorola Mobility RAZR v3xx Cell Phone
Can you increase the speed on the new 350 razor dirt rocket
MX350 is a 24V bike.
You could change the gearing by replacing the sprockets, or you could replace the electric controller and upgrade to 36V, but you probably would be better off getting a bigger model, like the MX500, as this uses 36V already and the higher voltage allows for higher motor rpm.
Dec 26, 2012 | Razor MX350 DIRT ROCKET - BLUE
I HAVE A 1999 SATURN SL PUT NEW CLUTCH IN AND A NEW PREBLEED CLUTCH MASTER CYLINDER AND SLAVE CYLINDER,HAVE GOOD CLUTCH PRESSURE WHEN PUSHING DOWN PEDAL BUT CLUTCH IS NOT ENGAGING. ANY IDEAS?
Are you certain you or your mechanic installed the clutch plate facing the right direction? It is usually marked on one side to tell you which way to face it. I have personally done this and had the same issue, if the hub portion of the plate is rubbing on the flywheel it won't kick out or in all the way, and if left it can cause damage to the flywheel.
Good luck.
Good luck.
Apr 04, 2010 | 1996 Saturn SC
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Psp anolog button faulty?
You just remove the face plate again and check it now your PSP is working OK if so there is some misalignment while placing the face plate on PSP and suppose your fault still remains same without face plate also then there is a possibility of Analogue button is being damaged which should be changed.
Feb 27, 2008 | Sony PlayStation Portable (PSP) Console
Help
ts simple man but u have to open the screws from behind then it will b done
Nov 28, 2007 | Motorola Mobility L6 Cellular Phone
Replacing the face plate for the 7370/7373
take the phone to a mobile center and have them replace it for you.
Nov 09, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Black powder on skin after shaving.
If you have dark hair, or dry skin, this could be the reason for the covarage on your skin. The shaver is cuting your hair, then "spiting" the hair back to your face.
Apr 24, 2007 | Remington Precision MB-50 Beard Trimmer
Motorola Mobility RAZR V3c Cellular Phone Logo
117 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
