Question about ASUS F3Jc-AP141C Notebook
Will not work
The unit has completely died , there is absolutely nothing working even with the power supply connected wich is supplying the correct output . It gives the impression that it has a blown fuse , but I can not find one . Regards , Peter.
  • millview Sep 04, 2007
    Thanks for that , but battery is nearly full , and there is no fuse to be found on the Mother board or anywhere else I have looked .
    Genius:
  • 1,153 Answers
Have you tried another batt, reason being is that if the batt. is dead and the power works but is not connecting inside then it gives the indication that nothing works. If you can check batt. and find power then look for fuse. Now fuse may not look like a regular fuse, if you can open and look in the power supply area then and check fuse resistors, diodes anything that could be open.
Posted on Sep 04, 2007
SOURCE:
I have a brand new power supply for the unit but system won't turn on
might sound silly,but have you turnd on the power switch for the pc if it has one,and the one on your power supply,
if you have check the fuse in the power supply,or check the fuse in your main power lead.
Mar 29, 2015 | Computers & Internet
What is most likely the problem when I push power button and I get nothing, no response at all, Power supply or Mobo ?
First of all, I'm assuming that you've connected everything correctly. I would think if absolutely nothing happens, it's probably the power supply. If a motherboard is bad, the power supply will still flip on, you'll hear the fan, and then nothing will happen. So your best bet for fixing this is replacing the power supply. Possibly with one that has a higher wattage.
Jul 29, 2011 | HP Computers & Internet
Intel S3000AH dont start (any fans or nothing else), only led under ATX connector lit when power cord is connected. Server work correctly yesterday, i poweroff it and try to boot it again today, but it...
1st try to change power supply (if you have a spare one). If this dowsn't work remove device by device (HDD, DVD etc) until You get some results. If fan on cpu is not working it power unit or MB error
Mar 03, 2011 | Intel S3000AH Motherboard
I was playing my game today and suddenly the monitor died. the computer works fine but the monitor wont even take the picture(wont even work without being connected to computer, like it has no...
You need to check the power supply and see if the output voltage is correct, it should be written on the power supply board by the out put connector, if it is correct then it is possible that the inverter is bad.. I suspect a bad power supply.
Oct 15, 2010 | Samsung SyncMaster 720N Monitor
When i boot upthere is nothing can see in my pc even no lights at all.the power supply is ok model is ms-7104 ver 3.2
Hello
With no lights at all it means that motherboard or power supply are dead or you didn't connect correct the cables
You hear the power supply working?
Jan 18, 2010 | MSI Computers & Internet
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
I am not able to boot the computer
Replace the power unit. Go to eBay to find a reasonable priced one. They are fairly simple to replace, just make sure you are grounded and that you hook everything back the way it was. You will need the part number to find the exact one on ebay.
Oct 03, 2009 | IBM (24P6829) for NetVista M41 160-Watt...
System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
Notebook wont boot up
it may be power supply unit problem , if it is in warranty contact the authorized service center
Jul 13, 2008 | HP Compaq nx6110 PC Laptop
Motherboard not working correctly.
The way that I solved the problem was to unhook each and every connection to the motherboard except for the 4-pin and 24-pin power supply connections, the processor, the cpu fan and the power on switch connectors, once I have done that, then I plugged in the power supply and turned it on, in which that worked! After that, I would hook everything up to the motherboard one piece at a time, in which after each piece I would turn the power supply on again to see if that was the problem. Starting with the hard drive, the memory sticks and then the DVD drive, and found out that was the problem. The cable between the DVD drive and motherboard was the wrong cable for that motherboard. I will purchase a new cable and see if that works!
Apr 21, 2008 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
ASUS F3Jc-AP141C Notebook Logo
373 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
