Question about Compaq (480082-001) ( 480082-001 ) Power Supply
Presario S4020wm desktop
Recently the computer will suddenly and randomly shut down, then restart and continue to act this way, cycling on and off. After removing plug from wall and waiting we can restart the computer but soon the same problem will occur. Suspected heat and cleaned all dirt and dust out. Checked cpu fan and PS fan. Played additinal fan on PS and ran all day. Closed up computer and after several hours the problem started again. Suspect PS but not sure. Does anyone have similar problem?
  • 2 more comments
  • jim73 Sep 06, 2007
    The problem doesn't appear to be the fan, but it is a possibility. Sounds like a worthwhile approach.
    Looking into line voltage and load on the power supply.
    Is an exact replacement fan available?
    Fan sounds like a possibility, but seems ok.
    Looking into line voltage and load. Line voltage may be a problem with air conditiners running in house.
    Load appears normal. Standard mother board, 1 CD drive, 1 hard drive, one floppy, normal video card and 1 modem card.
    Is that specific fan available anywhere?
  • jim73 Sep 07, 2007
    Pursuing the house line power for any problems.
    Apparently the "power-good" signal would cause the exact symptom that we are experiencing.
    It operates as follows:
    If the power supply can't maintain proper outputs, (like a brown out), the "power_good" signal is withdrawn and the processor automatically resets.
    When the power output returns to its proper levels, the PS regenerates the "power_good" signal and the system again begins operation ( as if you had just powered on).
    This is precisely the kind of behavior that the computer is showing, so it is telling us something.
  • jim73 Sep 08, 2007
    I agree. The thermal overload would give the same or similar symptoms. When we operate the computer with the case open or with a small fan on the PS, the problem diminishes. Unfortunatly we did this at another location, so we have to discriminate between the thermal, (supply does not seem to be especially warm), and the power source at the original location. Always happens when you do two things at the same time.
    Will try to determine which before investing in a new power supply.
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Posted on Dec 28, 2007
Same problem here.. power switch shorting. Either replace it, rig one up, or unplug it from the mother board after startup!
Posted on Aug 15, 2008
  • 883 Answers
Yes, the power supply fan is either slowing down and allowing supply circuit to heat to a point where a thermal detector detects a shutdown condition, or the supply fan may be turning off. I had similar problem and solution was a new power supply fan.
Posted on Sep 05, 2007
  • 3 more comments
  • Marty marty Sep 06, 2007
    so the new power supply fan was not the solution? did you get an exact match fan?
  • Marty marty Sep 07, 2007
    yes, inspect your house voltage for issues first. make sure no power dropouts. also try swapping breaker in house panel with another breaker.
  • Marty marty Sep 08, 2007
    thermal overload exhibits the same symptoms, though. try to monitor the power ok signal for dropouts (using a record-able voltmeter). if you can't, one solution is to try another power supply.
  • Marty marty Sep 13, 2007
    so all this help is rated as NOT HELPFUL?
  • Marty marty Oct 06, 2007
SOURCE:
I have a S4020WM. I installed a new video card. The computer was running slow and my Start Menu task bar was missing. I rebooted the computer and ran in safe mode. I shut down the computer. The next time I...
i cant understrand how you got to VGA card
PC ran great before but not after card stuffed in
nor if PC had a card before, then changed it a different card
Some PC have VGA chip on board and need no card. for VGA.
onboard fails, or it and the existing card fails the add 2nd card and it fails.... there is story here you never told.
The OS is corrupted.
reload, XP.
XP is a virus magnet, id up graded it.
but if you love danger.
there is only 2 ways to restore.
1: the F10./F11 restore key
I first carbon date pC, ,after age matters, things go obsolete fast.
so. how old is the beast. real name.
Compaq Presario S4020WM this pc is 100% RETIRED< zero support by HP
https://support.hp.com/us-en/retired-products
i found, that it does have onboard VGA 15pin jack
center of read MOBO.
so do both fail>???????????????????????????
try some install disks to reinstall the os
try F8, yes, F8 dead, means the OS is corrupted
needs OS reInstalled, for sure.
buy the disks from HP or 3rd party
Mar 22, 2017 | Compaq Presario s4020wm (DK214AR#ABA) PC...
I need to acess the BIOS on my PREsario s4020WM but i need a password to do it is old and was my parents so i cannot figure it out so i jut need the options of what the password would be or how to reset it
Disconnect the power. Remove or reset the jumper near the cmos battery. Connect and turn on your computer for a minute. Turn it off. Reset the jumper to it's original setting and you're done. Put everything back together and you're good to go. Good luck!
Dec 19, 2010 | Compaq Presario S4020WM PC Desktop
I need to replace that front usb ports on my compaq Presario s4020wm Can they be replaced
I think it would be much easier for you to use a USB hub instead.
It's much more easily available .
You can connect the hub to one of the rear USB ports
Mar 28, 2010 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Random Restart or Computer Freeze
what you did is OK for minor fixes. mostly for application error.
you need to format the hard drive and install the OS again in order the OS to work properly. you may have some file that is left over that is cusing the shut-down.
Dec 30, 2008 | E-Machines eMachines Desktop PC
Presario v6000 Sart up.
After reboot, before restart, take the recovery CD out and let the computer start from hard disk. Let me know what happens.
Nov 30, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Compaq presario s4020wm
you mean the internal power supply? that's available for around 20 bucks anywhere online..usually called a PCXT power supply..big issue is finding one that's identical with connectors..
take yours out, and then maybe there will be a part number or maker on the label.
Mar 09, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Compaq (480082-001) (&#160;480082-001&#160;) Power Supply Logo
269 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
