Question about Acer TravelMate 2300 Notebook
Keyboard not working on acer travelmate 2350
Hi, I am facing a strange and intriguing problem on my acer travelmate 2350 laptop. After bootup of windows xp, no keys on the keyboard work. On some rare occasions, the keys are found to work, with the exception of the function key and some other keys. For example, when the '5' key is pressed this combination appears and keeps repeating: . Only if a press a combination of backspace and '\' together, does this repitition stop. I am absolutely no idea how to get around this bizarre problem.
  • shiraz Sep 05, 2007
    It seems that the problem is with the key hardware itself as you have pointed out. The driver re-installation did not work
    President:
  • 2,961 Answers
It could be the sensors are damaged under the keys, but hopefully its just the driver. Right click on my computer icon and click properties and then the hardware tab, then device manager and look down the list for keyboard. Click the + sign and then right click on your keyboard under that and select uninstal. Restart the notebook and it will reinstall itself and hopfully work as it should do, if not then the keyboard itself is damaged in some way.
Posted on Sep 05, 2007
  • andrew pester
    andrew pester Sep 05, 2007
    Yet again the solution was correct and yet a poor rating, the diagnosis is correct and unless you can fix the keyboard yourself you will have to take to a repairer.
SOURCE:
My acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
my acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
Jan 30, 2010 | Acer TravelMate 2300 Notebook
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
Touchpad not working
Hold down the function key Fn and tap the F7 key,
now try the touchpad
Jan 23, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Touchpad in Acer TravelMate 2350 stopped working
hmm... goto control panel, double click on mouse icon
click on Device Setting tab and Click on Enable button and finally................. :))
Thanks
Iqbal
Apr 01, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 2350 boot password
Do u know to use Soldering iron...if u know..remove the proccessor from socket then de solder the BIOS batterry and short that two terminals on mother board without connecting the power adapter and battery...do it and re solder the bios battery..this procedure will help u to recover from ur problem..if u dont know then do it with any technician.
Dec 09, 2007 | Acer TravelMate 2300 Notebook
Acer Travelmate 2350
if your cdrom stops installing the operating system, then either the processor is damaged or the hard drive is faulty, as initially the installation files have to be installed to run the main O.S installation
Sep 21, 2007 | Acer TravelMate 2300 Notebook
Keyboard not working on Acer TravelMate 2350
Yes but you still wont be able to enter your passwords etc Your key board is faulty
Sep 13, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
363 people viewed this question
Ekse
Alun Cox
