Question about Neoware Systems c50 Thin Client Network Terminal
The whole OS is gone
When I tried to install a Snap in on my TC the machine rebooted on a certain moment and after that the whole O|S was gone. All I get is a C:\ prompt How can I restore the OS? Any help would be really appreciated
  • brtsch Sep 11, 2007
    hi, thanks for trying, but it did not help. All I get is the C:\ prompt no matter how hard I push on the F8 key :-(
    We are using Windows Terminal Server 2003 and originally there was supposed to be WinCE on the Thin Client. The TC was supposed to start from HDD0
    Problem Solver:
  • 6 Answers
Hi brtsch Your problems means there is nothing wrong with ur terminal. your terminal server is not starting try booting with last known good conf by pressing F8 option if it dosent work then try with safemode and uninstall what u have install pls mention which server ur using and OS and also if any error codes
Posted on Sep 05, 2007
SOURCE:
CANNOT GET PAST BLUE SCREEN
Have you tried to cold start the machine, remove all media, CDs, DVDs, USBs, etc., unplug, remove battery, plug in , Try to boot normally. If that fails, unplug, plug in, reboot and try your F key to Boot menu or system restore/recovery. Does the HDD spin-up? Led blink? DVD/CD rom drive led blink? Do you have a repair disk? Does your laptop have a few miles on it? Could be a bad HDD? Remove and test, replace if necessary. Try to reseat the HDD and the memory mods First.
Nov 18, 2012 | Fujitsu Siemens AMILO Pro V2010 Notebook
My computer was a blue screen, what is the solution?
Blue screen or blue screen of death (BSOD) is common with windows family of operating system and it happens to stop any damage to your system when OS fails. If it happened once, nothing to worry about but if its happening again and again, you need to check for any recently installed hardware or software, it maybe incompatible. If this is not the case then maybe you need an upgrade.
May 05, 2011 | Computers & Internet
Frequently get a blue screen with a Fatal Error message.
Blue screen while running indicates that the OS (one of the file) has been as been corrupted.... Re installation of the OS will solve the problem
Thanks...
Jul 19, 2010 | Dell Dimension 3000 PC Desktop
I just upgraded from os x 10.3.9 to os x10.5.6. Now on start up I get the grey screen with rotating wheel then a darker grey screen with message to reboot the computer. I can get no further.
Not a good sign but not the end of the world. Put the install disk into the Mac and hold down the option key (in a moment you'll see two disk icons appear) once you see the icons, click on the install DVD then up arrow in the circle.
When you get to the install screen click next thru the next couple of screens. You should see a menu bar at the top of your screen, click and hold on utilities then select Disk Utilities. When Disk Utilities is running on the left side of the window select your Hard drive (not the DVD) On the right hand side some new options should appear, Click on First Aid if not already selected then click Repair Disk Permissions.
When complete restart the machine normally (DVD should eject) If that does not fix it you'll need to try the install again.
Jun 16, 2010 | Apple Mac OS X 10.4 Tiger for Mac
My laptop won't hold on battery after loading OS
Well the battery isnt holding the charge so you need a replacement it happens if there on the shelf for a year or more thats wy you buy direct
Apr 26, 2010 | Toshiba Satellite A105-S4284 Notebook
I have a compaq presario 1200 laptop and I have a blue screen problem. Whenever I run anything memory intensive it simply flashes a blue screen at me then reboots. Whats more is after it reboots it won't...
Your Operating System (OS) is corrupted.
The best solution to this problem is to reinstall your OS using an OS installation CD.
I would also recomend upgrading to Windows XP.
You can upgrade by simply installing Windows XP on your laptop.
Back up all your data before reinstalling your OS.
Jan 07, 2010 | Compaq Presario 1200XL104 Notebook
My meccer extreme keeps rebooting it has an asus p5gl-mx motherboard 512mb ddram
Reinstall the OS using a bootable OS CD. By the way, what is the OS you are using? Some OSes can be repaired without installing the whole thing.
Sep 01, 2009 | ASUS P5GL-MX Motherboard
Again hep me
just try to reboot the machine,the press F8 when the prompt comes the choose safe moode,the moment you enters windows desktop then reboot the machine. if it won't boot again then just repair winXP OS It will solve the problem for you.
[email protected]
Mr CPU......
Apr 05, 2008 | HP Pavilion dv6000z Notebook
IMac G3 unable to boot up
OSX isn't compatible with the older G3's.
Mar 26, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
Question
You mean the setup doesn't load? Also when installing Windows, the first part it copies data to the just formatted harddrive. Then it reboots, but make sure it doesn't reboot from CD because then it wil start all over again. It must boot from harddrive after it copied files to your drive.
The setup data is located on you HDD from that moment on.
Or isn't this what you mean?
Greetings,
DarkNeogen
Jan 24, 2008 | Maxtor Hard Drive
Open Questions:
Neoware Systems c50 Thin Client Network Terminal Logo
164 people viewed this question
Top Neoware Computers & Internet Experts
Ekse
George Etukudo
George Etukudo
Dennis
Dennis
Are you a Neoware Computer and Internet Expert? Answer questions, earn points and help others
