Question about ASUS VW192S Monitor
Auto Adjust Every time I turn off and then turn on my Monitor it auto adjusts. Also if I restart my computer again it auto adjusts at the start up. How can I disable the auto adjust feature?
  • 5 more comments
  • Enter Oct 02, 2007
    anyone knows???
  • Anonymous Aug 03, 2008
    my computer flashes auto adjust in progress
  • durbasharper Sep 02, 2008
    my computer keep saying auto ajust how can i fix it
  • Anonymous Sep 06, 2008
    turn off auto adjust
  • Anonymous Sep 08, 2008
    Each time I turn on the computer the Auto Adjust in progress starts to flash and continues . It is very annoying. I cannot see anything behind the flashing sign. Even typing this msg. I could not see what I was typing. I would appreciate a solution to this problem.
  • fcooze Sep 27, 2008
    Auto adjust is running the colors are off, howdo i fix this
  • pattimac Oct 07, 2008
    the auto adjust keeps flickering on screen every time i touch the mouse-really annoying. Anyone know how to disable the auto adjust?
I have found a way to stop flickering of auto adjust - press the menu key on your monitor -factory reset-menu button-all settings. That has solved my problem and hope it helps you.
Posted on Oct 08, 2008
    Guru:
  • 134 Answers
There are a couple of things that you can try...
1. Setup on Monitor..: check on monitor menu, if the feature auto adj are enable,.try to Reset setting and resetting your display.
2. On windows(xp) desktop click Start > All programs > Startup... See for apps has executed for starting window. if you see "Adobe Gamma Loader" installed, maybe you haven't to saved your gamma/bright setting (it also happen when the first time installing adobe reader/photoshop, etc) you can resetting by "right" click on desktop > properties > click on Setting tab > click advance > Color management. after done, click apply then ok.
if The picture on monitor is upside, do resetting on monitor menu, > select V POSITION. (Vertical)
Hope this be of some help/idea. Pls post back should you need additional information.
Posted on Nov 13, 2007
Go to My Computer and right click Local Disk (C):
Go to properties and click on the tab Tools. Press Check Now on error-checking and check the top box to have a disk checkup during startup. Click yes to the question for schedule and then restart your computer and wait for the window to fix any system errors. hope this will help.
Posted on Jul 29, 2009
Processing auto image adjust appeares more times
open the rear cover there is a trimmer, with a screw drive adjust it by turning right or left; the message will not appears again
Oct 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Auto adjust in progress, want it removed
Your video card or monitor sounds like it might be malfunctioning. Have you tried another monitor? Does it show anything on the screen after turning on the computer? If it does then goes to "Auto Adjust" then try restarting and pressing F8 over and over until you get a menu. Then select VGA Mode. Change the screen resolution by right clicking on the desktop and clicking "Properties" then the "Settings" tab. Use the slider to lower the resolution and then restart.
Aug 03, 2010 | Microsoft Windows XP Professional
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
Jul 10, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
My computer monitor keeps saying auto adjust how do i fix this
Usually if the auto adjust is flickering intermittently you can attempt to reset the internal values to the factory settings. To do so: press the menu key on your monitor then choose factory reset. Press the menu button again then select all settings.
Jun 19, 2010 | ASUS VW192S Monitor
Pop up auto adjust in prograss
I had the same problem with my HP LCD. I'll turn on the monitor and it will run auto adjust and set everything to the max making the screen very bright. What I did was remove the button panel board and put it back. Everything works fine since then.
Jan 09, 2009 | Dell E173FP 17" LCD Monitor
Need to Auto Adjust Envision 20" monitor every time
yes it may be a memory problem inside the monitor replace the memory from technical person
or refer the manual with the monitor some trick may given so that push menu twotimes or operate like mobole button
Nov 09, 2008 | Proview PX-986 19" CRT Monitor
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Auto adjustment comes on every 5 seconds
Sometimes that can be caused by a loose or bad video cable causing the monitor to re-adjust for the video signal. You could try resetting the monitor by unplugging it for a few hours and re-plugging it again too. Also check with HP and see if they have any warranty, extended warranty, repair notice, free repair/ replacement.
Jun 21, 2008 | HP f1905 19" Flat Panel LCD Monitor
Auto adjusting
Try wiggling the auto adjust button on the front of the monitor, it sounds like the button is jammed against the switch causing it to auto adjust over and over.
Mar 21, 2008 | Gateway FPD2275W LCD Monitor
ASUS VW192S Monitor Logo
14,407 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
