Question about Frigidaire GLTF2940ES Front Load Washer
Error : LOC
I use to think that is is LOCK (door); So I ordered lock switch , replaced it , but got same error. Please advice.
Thanks! I was able to fix the problem before my husband smashed my machine!!!
Posted on Oct 15, 2007
I have the exact same problem. Found this posting: http://www.applianceblog.com/mainforums/showthread.php?t=846 From "John": "The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too." I pressed both *OPTIONS* and *SELECT* as suggested... worked like a charm.
Posted on Sep 24, 2007
SOURCE:
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Fdl code
Your door lock switch needs to be replaced... Fdl is a door lock error.code. This error shows up because the door cannot be locked. The door will try to lock six times before displaying the error code
You can order a new part replacement from the Sears PartsDirect website.
Hope helps.
Sep 25, 2011 | Washing Machines
What is an error code of DL?
F/dL error - Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
Good luck.
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Hi - my washer machine stops mid cycle then beeps and shows a dL code. what does this mean? How can I fix this?
Listed below is the meaning off the error code, and corrective actions needed.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Replace failed component.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
FRIDGIDARE WASHER MODEL LTF6700FSO DOOR LOC ERROR. DOOR WILL NOT LOCK. HOW DO YOU REPLACE THE DOOR LOCK?
How old is this unit? Usually these locks cost an arm and a leg. This is especially true with units like: G.E, Frigidaire, Hotpoint...These are units that are owned and operated under General Electric. First, if you have a volt-ohm-meter, do a continuity check on the switch itself. Then if that checks out, your next culprit would be the main control board (most likely).
Dec 14, 2009 | Frigidaire Dryers
Door wont lock.
loc is a door lock error. it has failed and needs to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Potential Causes
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error F dT. washer won't start.
There is no such error in whirlpool fault code libraries as "F dT".If it is "F dL" then it is explained as follows.Please do clarify.Thank you.
FdL - Door lock error
Potential Causes
Please do rate my solution if accepted,else will await your further comments.Will be glad to help you out.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
Potential Causes
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
105 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
