Question about Motorola Mobility RAZR V3
External screen blank, blue backlite
The external screen that used to display time and incoming calls is now just a blue background. I did not drop it. Any thoughts ?
    Brigadier General:
  • 7,752 Answers
Have the LCD screen replaced take it to a mobile service center and have it replaced there.
Posted on Feb 22, 2008
SOURCE:
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Display on dell d 610 wont turn on
Display won't turn on? You mean the screen is blank? If so it can be that the lcd screen is bad, the lcd inverter is bad or the vga video card is bad. You can narrow down the problem by plugging in an external monitor into the laptop then press FN+F8 keys to get the display on the external monitor. If it shows on the external that means the video card is ok. If the video is ok remove the external monitor and reboot again. Use a flashlight and shine it on the display if you can bearly see the icons in the background, that means the lcd inverter is bad and needs to be replaced. If you see nothing and the computer has booted up, the fans are running the lights on the right under the lcd shows the disk blinking and the powerlight is on, then you probably have a motherboard issue. Contact the guys at: http://www.generalsystemsconsulting.com
They will fix it and return ship it by Fedex or UPS. Get a quote a your local computer shop, then call them
Mar 10, 2012 | Computers & Internet
Must be reset router tl-mr3420 tplink time to time after connecting DVR Hikvision externally via NO_IP. the router has DDNS enabled and open port-forwaring
1.You will possibly need to configure the router for what is called "port Triggering"
2. from what I read is that there is no IP via the Hikvision external there fore requiring a new IP each time for connectivity.
Instruction set from the manual states:
To add a new rule, follow the steps below.
1. Click the Add New... button, the next screen will pop-up as shown in Figure 4-40.
2. Select a common application from the Common Applications drop-down list, then the
Trigger Port field and the Incoming Ports field will be automatically filled. If the Common
Applications do not have the application you need, enter the Trigger Port and the
Incoming Ports manually.
3. Select the protocol used for Trigger Port from the Trigger Protocol drop-down list, either
TCP, UDP, or All.
4. Select the protocol used for Incoming Ports from the Incoming Protocol drop-down list,
either TCP or UDP, or All.
5. Select Enable in Status field.
6. Click the Save button to save the new rule.
check the "Local management" in the router
you must allow certain devices to obtain an IP via either MAC address or IP address.
Sep 12, 2011 | TP-LINK TL-MR3420 Wireless Router
Im a user of Laptop nc6230 for long time , not i found a problem with my laptop. Same time when i switched on the laptop, i can hear everything sound,fan but the screen remain blank. And some time it...
@rashid386
If you turn the computer ON and you can hear that something's running on the background but there's no display , this is a sign that the screen's FL Inverter (this is the chip that controls the backlight of your LCD) or the LCD screen itself is already wearing out and needs to be replaced. If you can see a background image but there's no backlight - you need to have the FL Inverter replaced. If the screen is all black, you may need to have the LCD screen replaced. If you know your way around the computer, you could order screen replacement here and disassembly guide here.
Good luck.
Sep 11, 2011 | HP Compaq nc6230 Notebook
HTC P3400i display is not working,blank white screen is visible. incoming call is OK. What can be done on this? What is the cost of new Display to upgrade?
Oct 18, 2010 | Cell Phones
Trouble hooking external Viewsonic monitor to Toshiba laptop
If I understand You are using a Monitor connecting the Monitor...
and the background is shared byboth the display however the Cursor stays only on one of them at a time.However it can be toggled among the 2.
If yes,
then this Feature is called the Extended Display.
Use the same Key Combination that you would use for external Display one More time and it should Work.
Jul 03, 2008 | ViewSonic VX924 19" LCD Monitor
Santa brought us rca pearl th1101 and it says it has 7 different backlit color displays
I do not know about the color change but here is the number to RCA main support 580-634-0151
Dec 26, 2007 | RCA TH1101 MP3 Player
External Display
This is a hardware issue. The flex cable connecting the displays is loose or broken. If the phone is new, you can get this repaired under warranty.
Dec 01, 2007 | Motorola Mobility RAZR V3
Motorola RAZR
your external screen needs replacing...you would have to take it to an authorised repair person to replace it because it's very tricky to change. Sam !
Sep 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
142 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
