Question about Motorola Mobility MD681 Cordless Phone
Please help me
The answering machine answers but does not record any messages, I also can not set the time and day
  • 10 more comments
  • Anonymous Nov 13, 2007
    cannot set time and day
  • raeol Nov 22, 2007
    Same problem - answering machine records caller's message, but when retrieval button is pushed, voice says, "You have no messages." Several have told me they left us a message, but our machine still shows "No messages."
  • DCcrusher Dec 06, 2007
  • Anonymous Dec 12, 2007
    I am having the exact smae problem
  • Anonymous Dec 21, 2007
    i have friends that say they are leaving me messages but when i check it says that i have no messages. can you explain?? Model ceza1998
  • Anonymous Dec 27, 2007
    i cannot receive any messages
  • Anonymous Jan 08, 2008
    Messages have been recorded but the phone shows "0" messages. Please assist.
  • Anonymous Jan 14, 2008
    how to record a message on this phone
  • Wanru Jan 18, 2008
    I lost my Instraction. When I try pressed the meno record, but it did not work.
  • Summer79 Jan 24, 2008
    I was trying to change my message and when I did, since then when someone calls and leaves a message I don't hear anything and it says 0 messages? Can someone help, I don't have my manual anymore so I don't know what to do?
    Thanks Summer
  • joycl1 Jan 27, 2008
    My answering maching states, messages cannot be left at this number.
  • Anonymous Jan 28, 2008
    I have the same issue. The other thing to add is my answering machine shows CL then changes to A, then back to CL, and so on. I am assuming it is related. What does this mean? Any ideas? I set the outgoing message and this at least allows a caller to leave a message, but even though they think they are leaving a message it doesn't seem to store it. I am researching this issue and will post a solution if I find it. Thanks!
I spoke to soon. I found out what the CL and A are by looking at the manual. The CL indicates that the clock isn't set, so I set it. That most likely isn't your problem.
The A indicates that it is in announce only mode. That may be what is causing your issue. Press menu until it says announce only mode (or something like that), then press change to change announce only to OFF. That should fix your issue. At least that is something worth trying. Good luck!
Posted on Jan 28, 2008
I have ATT VOIP service. You are probably recording your messages on your ATT voicemail. Change the # of rings for the voice mail to pick to more than the answering machine picks up. You have to get into your account and look for the section that allows you to do that.
Posted on Dec 27, 2007
SOURCE:
How do I set the time and date on my 43-3829 answer machine?
Hi, here are the instructions for setting the time on a 43-3825, which is a very similar model. They should work for your machine too.
1. Press and hold TIME SET/CHECK/>> until you hear it beep twice. 2. Press ANNC/DAY/<< and the machine will say a day. Keep pressing that button until you hear the correct day. 3. Press REC and the machine will say the hour. Keep pressing it until you hear the right hour. 4. Press >= (the play/pause button) until you hear the right minute. 5. Once you've gotten the correct day and time, press TIME SET/CHECK/>> to save it.
While you're doing this, you can't let the machine sit idle for more than 5 seconds at a time, otherwise it will exit the time setup and you'll have to start over again. Good luck!
Mar 15, 2010 | Radio Shack 3825 Answering Machine
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
How to get a message on a telstra m450 answering machine
To change the answer message, hold ans on/off then HOLD the skip back button, don't let go until you finish the message, to change the amount of calls untill it plays the answer machine hold skip forward button till it says how many the press the forward button till you are happy, to change date and time, hold stop, it will say the day to change press skip forward, then press stop again, it will say the hour, press skip forward, then stop the minute, then skip forward, then stop again to confirm, i belive it is in 24hour time as well, when changing the time, but not on playback.
Hope this helps
Feb 08, 2009 | Lands Phones
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Nov 09, 2008 | Radio Shack 3825 Answering Machine
Greeting message
To Record Outgoing Message on Radio Shack’s Answering Machine [Model 43-3829]:
Press and Hold the ANNC/DAY/<< button. You’ll hear a beep; continue to hold down the ANNC/DAY/<< button and record your message. When recording of your [outgoing] message is complete, release the ANNC/DAY/<< button. Your message will automatically play back for you.
Please let me know if you have additional questions. Thanks!
Take care,
Gail :-)
Sep 17, 2008 | Radio Shack (43-3829) Digital Answering...
Instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Jun 11, 2008 | BellSouth Digital Answering System 2006C...
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
May 10, 2008 | GE 29888GE1 Digital Answering Machine
Model#fa972 southwestrn bell freedom phone answering machine
Press the >>/Time Set button for about 2 seconds. The system will announce "Monday" press the >>/Time Set again to choose the correct day. Press <</Time Check to change to hours. Select the correct hours by pressing the >>/Time Set, then press the <</Time check to change to minutes. I can't get the mail box 2 to operate either.
Jan 06, 2008 | Southwestern Bell FA972 Digital Answering...
Howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
Nov 29, 2007 | GE 29878GE1 Digital Answering Machine
User manual for a Bellsouth answering machine model 1188
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Nov 11, 2007 | Lands Phones
Motorola Mobility MD681 Cordless Phone Logo
169 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
