Question about Compaq Armada 7400 Notebook
Laptop & Tv tunner card
It is not connection
  • 457 Answers
Re: Laptop & Tv tunner card
Do you mean it will not connect if so then is the tuner compatible to your Laptop. I think the TV tunner cards is a thing of the past. Correct me if Im wrong but the in thing is watching TV over braosdband and there are thousands of free to air over the net. Can you be a bit more specific...
Posted on Sep 06, 2007
0 characters
3 Points
Rgb connection stopped working on laptop
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell PC Laptops
Hello,everyone!! i have lenovo ideapad y560 with inbuild tv tuner & also a connector wire to connect dish cable to laptop... but my question is that how do i watch tv on my laptop OR in which...
TV tuner cards allow you to view programming on a computer system. Although desktop computers allow you to install internal TV tuner cards, laptop systems do not have the available space for internal cards. Because of this, laptop computers have PCI express card slots. This slot allows you to install and remove (at your will) additional hardware, such as TV tuner cards.
  • TV tuner card
  • Driver installation CD
  • Software installation
  1. Locate the PCI express card slot (located on the side of your computer opposite the disc drive). Push in on the protective cover on the slot to unlock it from the case. It pops out slightly, allowing you to remove the card.
  2. Slide in the TV tuner into the PCI express card slot. The card clicks into place and a light blinks on when the card has connected successfully to the laptop computer.
  3. Insert the driver installation CD into the disc drive of the computer. Momentarily a driver installation wizard appears on the screen. Click "Next" on the welcome page, then accept the given license agreement. Choose "Next" two more times, then select "Install" and the drivers from the driver installation CD install onto the computer.
  4. Eject the driver installation CD and insert the software installation CD. This is the program you use to view the connected receiver. As with the driver installation CD, wait for the installation wizard to load up onto the screen. Accept the license agreement, leave the installation name and location blank, then click "Install" to install the software.
  5. Restart the computer. Upon restart the laptop is ready to begin using the TV tuner card.
Jun 12, 2011 | Lenovo IdeaPad Y560 Laptop
How to connect tv tuner in lenovo nb610 laptop.
Welcome to Fixya
Dear USer
You can Connect any External TV tuner Card to Your Laptop.It is Very easy to Connect and Use.
Refer your Tuner Manual for more Details[because it depends on each Tuner Card]..
Hope you got it...Thanks for Connecting FIxYa....
Sep 02, 2010 | Lenovo PC Laptops
How can I watch Television on my laptop?
you may need an external TV tuner connected to your laptop, the cable signal/connection will be connected on the tv tuner.
Let me know for any clarifications
Sep 05, 2009 | Acer ASPIRE 5720-4649 Notebook
Connecting and recording camera with s video output on 1221 tx
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
May 17, 2009 | HP Pavilion dv6000z Notebook
Got a new Dell Studio 17 laptop with TV Tuner, but TV wont go
if it is not finding channels, it could be a physical connection problem from the antenna or the antenna lead on the device.
Mar 10, 2009 | Dell Studio 17 Laptop
Does this laptop reqiure a video card?
they have video cards but i don't believe it is compatible
for television
Jan 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
u must have tv input connection in ur laptop for watching tv. if so then ok if not install a tv tuner card in your laptop
Oct 31, 2008 | Sony VAIO VGN-N130G/W Notebook
About tv tunner card
Do a google search for a tuner in your area. Should give you a price.
Sep 13, 2007 | Compaq Armada 7400 Notebook
Compaq Armada 7400 Notebook Logo
89 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
