Question about LG Studioworks 700S 17" CRT Monitor
POWER SOURCE 110 VERS 230 VT
I HAVE JUST MOVED FROM NORTH AMERICA TO GERMANY. WILL MY MONIOTR WORK WITH EUROPEN POWER SOURCE? IS THERE A SWITCH OR SOMETHING SIMILAR TO THE SWITCH ON PC?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Some times they provide switch for 110/230 at the back side of monitor. but if you do not have that you can purchase converter which converts 110 to 230 volts ac.
Posted on Sep 26, 2007
6ya staff
SOURCE:
I have to go out in 10min but will return 4:30. I need a HANNSPREE TV HELP PHONE NUMBER. can you give me a working number?
Hello, Mike -
Hannspree North America:
888-808-6789 (
Mon - Fri: 8:00am to 5:00pm (Eastern Time)
Source:
http://www.hannspree.com/US/EN/ContactUs.aspx
Hannspree Europe
See:
http://www.hannspree.eu/en/about-hannspree/contact-us
Germany, France, Italy, United Kingdom, Spain & Portugal
Best wishes.
Mar 12, 2018 | Hannspree Televison & Video
I plugged the ac adapter of my n America grundig satellite 800 radio into a power outlet in london. Since then iam not getting any power ln it. What has happened
In North America, the voltage is nominally 110v. In London, 230. You may only have blown a fuse or the AC adapter, but you could have fried the whole unit.
Jun 16, 2015 | Grundig Audio Players & Recorders
Honda h22 5 speed
stalls. ( ever tune it up,at the 60k service points? )
what year, no year , no joy, 1978 to 2001 , lots huh?
and what engine option, displacement (size)
over 10 engines
Third-generation Honda Prelude engines:
B20A/B20A1 - 2.0L DOHC PGM-FI 143/160 hp (Japan/Europe)
B20A3 - 2.0L SOHC 12v carb 104 hp North America
B20A4 - 2.0L SOHC 12v carb Global, except North America
B20A5 - 2.0L DOHC PGM-FI 135 hp (101 kW) North America
B20A6 - 2.0L DOHC PGM-FI 142 hp (106 kW) Oceania
B20A7 - 2.0L DOHC PGM-FI 150 hp (110 kW) Europe
B20A8 - 2.0L DOHC PGM-FI 133 hp (99 kW) Europe
B20A9 - 2.0L DOHC PGM-FI 140 hp (100 kW) Europe
B21A - 2.1L DOHC PGM-FI 145 hp (108 kW) Japan (SI States)
B21A1 - 2.1L DOHC PGM-FI 140 hp (100 kW) North America
Jan 11, 2014 | Honda Prelude Cars & Trucks
Can I use my Element FLX 2611 B in Germany?
If the set is USA or north America format that is NTSC and in Europe a lot of places are PAL or Secam---means if USA NTSC set you will need a PAL/SECAM to NTSC converter--converts one signal type to another.
Only other possible issue is voltage---must be 110-120 volts AC and not 220 volts.
May 26, 2012 | Televison & Video
My hobart n50 mixer,when pluged in does nothing at all. why? and what to do?
The N50 is a heavy duty / commercial counter top mixer. It is available in several different versions for different power sources. Make sure yours is the model for use with the power available at your location. The power versions are:
100-120/60/1, 100/50/1, 230/50/1, 220/60/1 and 230/60/1
This lists the information in the following format: voltage/frequency/phase. If used in the US or Canada (and many other parts of the world) you would most likely want the 100-120/60/1 or the 230/60/1 version. All are single phase, so this shouldn't be an issue to worry about. Use of any of the other versions could result in shortened life expectancy of the mixer or immediate, catastrophic failure of the mixer and possibility of burns, shock or electrocution if connection is attempted.
If the mixer matches the power available, check for proper wiring at the source point of connection and in the mixer. You may need an electrician to change the power at the connection point from 100-120/60/1 to 230/60/1 (or vice-versa since BOTH are available in North America). Also check to be sure that fuses or circuit breakers in the electrical panel are intact and on. Do not overlook GFI outlets if using the 100 to 120/60/1 version. Reset any tripped GFI outlet. If still unable to operate, verify that power is present at the connection point. If unable to operate, contact an electrician to check the power and wiring of the mixer.
The mixer data sheet is available here.
Jul 12, 2011 | Hobart N50 Stand Mixer
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
Oct 20, 2009 | Computers & Internet
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
Sony PlayStation Portable (PSP) Slim (PSP-2000)...ver 3.6... i bought my psp in japan, im from philippines. i want to upgrade my system. where can i get psp firmware update? most of the sites giving...
this is a problem, only japanese games will work in a japanese console. Or, you can get custom firmware for psp(google it) and you can play games from any region, be it europe, japan north america etc.
Jun 10, 2009 | Sony PlayStation Portable (PSP) Slim...
I misplaced the power supply for my visioneer 4400usb scanner. Can anyone tell me the voltage output to the scanner?
Power supply
Input voltage/frequency 100 Vac, 50/60 Hz (Japan)
120 Vac, 60 Hz (North America)
230 Vac, 50 Hz (Europe)
Output voltage/watt 12 V DC, 15 watt maximum
May 24, 2009 | Visioneer 4400 Flatbed Scanner
LG Studioworks 700S 17" CRT Monitor Logo
50 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
