Question about Toshiba Satellite 1715XCDS Notebook
Hard Drive Replacement
I Would like to install a larger HD and do not have the original manual to physically locate the hard drive - Where is it?
    President:
  • 2,961 Answers
There are normally 2 panels underneath the notebook, you need to remove one or the other, normally the right hand side and then remove a protection plate and you will see the hard drive located in a metal sleeve holder, althogh you may need to remove the battery and the heatsink fan to get at the hard disk cradle. Simply slide the cradle away from the motherboard and the HDD should slide out.
Posted on Sep 04, 2007
SOURCE:
My lappy hard disk is giving status that hard disk failure try to install in other location. then i connected it to my pc to take backup
Not sure I understand your Question... or maybe you are making a statement? But, it sounds like your hard drive (HD) is dead, no good , non useable... So what are your options? Purchase another hard drive, you should have received system backup disk or install disk with your laptop , you can use them to reinstall the operating system (OS) Windows on the new hard drive. There is a slight possibility you could try them (the install disk) to re-install your OS on your original HD, but again it sounds like your HD is dead.
If you have never made a back up of you hard Drive, then all your data (pic, documents, game, contacts) are lost. The problem most people don't understand is if the hard drive crashes for physical reasons, the spring breaks inside, or a diode burns out, then the data on the disk are lost.
You may also take your laptop to a computer repair shop near you and they can tell you more about your options.
Jun 25, 2015 | Hard Computers & Internet
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
Needs to be larger
What needs to be larger ?????
If you need a larger hard drive other hardware might need to be upgraded to cope with the bigger hard drive although newer computers should be able to cope with a bigger hard drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these
then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
http://www.youtube.com/watch?v=EHxZN_NSiRI
Install a WD Hard Drive in Your Desktop
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
You Tube video install a second ide hard drive
Oct 07, 2013 | Computers & Internet
Can I replace orig hp ze1115 20GB hd w/60GB hd?
No the bios should be able to read the drive fine. The problem could be with the computer's motherboard. You should check to see if the original drive and new drive is detected in another system. Or you can try accessing them via an external casing / adapter.
May 25, 2010 | HP Pavilion ze1115 Notebook
The hard drive died, can I install Western Digital Scorpio Hard Drive - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal (WD1200BEVE) to replace it
You should definitely try out if it fits inside the bay first.
The original drive in the M55-S135 has a height of 8mm and the WD1200BEVE is 9.3mm. This is not a big difference and may pose no problem, but you would like to have all covers close properly later, I assume.
Other than the slightly larger physical dimensions, the drive should be fully compatible with the laptop.
Feb 12, 2010 | Toshiba Satellite M55-S135 Notebook
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
HDD replacement for Toshiba Satellite M35X-S114
should be no problem adding a larger hard drive....If I were you I'd compare some prices of Hard drives and choose the one thats suits best...you're not restricted to toshiba hard drives either....advantages of installing a larger hard drive really relate to what you use the laptop for....if you store lots of music or have lots of big programs then a larger hard drive makes sense....also you'll find it easier to get a 60gig hard drive than a 40gig as that size of drive is quite rare nowadays
Dec 17, 2008 | Toshiba Satellite M35X-S114 Notebook
IBM R40
The error indicates that the hard disk requires replacement. To my understanding, a 40GB Hard Drive was originally installed which you can replace with a larger capacity. Any brand/model actually would do as long the physical dimensions and fittings/connectors are identical.
Replacing the hard drive of course would mean that you have to reinstall your OS and all of your applications. This would be easy if the laptop originally came with recovery CDs. Should they not be available, any OEM installer of your original OS would serve the purpose. Drivers and appropriate software/utilities are downloadable here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 08, 2008 | Televison & Video
Toshiba Satellite 1715XCDS Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
