Question about Intel Motherboard
Msi 6524 jfp2 connections
Need help istalling
    President:
  • 1,114 Answers
You can download the manual from the link below: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=303 This has the installation instructions. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 04, 2007
SOURCE:
VGA DRIVER FOR ms 6524 ver 1 motherboard NOT INSTALLED NEED FOR MY COMPUTER
Here's the AWARD BIOS for you msi (Micro Star International)
ms 6524 mainboard/motherboard. It comas as an executable .EXE file. Upgrading/reinstalling your motherboard BIOS may solve your VGA "driver" problem, but drivers are
really the province of MSDOS/Windows - motherboards know nothing of drivers, and simply provide a BIOS to interface between the operating system drivers (the OS can be Linux,
or MS windows, or anything).
http://www.msi.com/product/mb/MS-6524.html#/?div=Download
To get the VGA driver for your MSwindows system, access your C:\Windows\drivers directory where you should find the file "vga.sys," which is the generic VGA driver for MSwindows. This driver will be referenced in the installation file Oemsetup.inf, which you will find in the C:\WINDOWS\inf directory - its ASCII, so you can open it up and read it with "notepad," or your favorite editor.
Use this link to determine which Video driver windows is actually using
when it boots (WinXP only):
support.microsoft.com/kb/314854
Use this link to FORCE windows to use the default VGA driver
even when running an unsupported monitor (which I suspect could be the problem you're facing).
http://support.microsoft.com/kb/268852
Jun 09, 2011 | Computers & Internet
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
Looking to plug in my main switch and need help with finding the right port(s)...only see one color coded set of pins available....
Open the link provided below by MSI;
Download and install Adobe reader to view manual.
Adobe Free; http://www.adobe.com/products/reader/
Manual for K8T Neo-FSR;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo-FSR
Download the maual if needed. Open to page 2-20.
Use the manual to connect you're case wires to the motherboard. JFP1 provides power to Reset Switch, HDD, Power on switch and Power LED. Use JFP2 - connect internal speaker. (Bios uses this for POST).
Power On Self Test. If you use Adobe you can zoom in on pg. 2-20 which will help you connect each set of wires to their matching MB pins.
Cheers'
Mike
Feb 18, 2010 | MSI K8T Neo-FSR Motherboard
NEED MANUAL FOR CONNECTORS "JFP1" AND "JFP2"
You can download the manual by clicking this link:
http://download3.msi.com/files/downloads/mnu_exe/M7104v1.0.zip
The connections for JFP1 and JFP2 are given on page 13 of this manual.
Hope this solves your problem. Thanks for using FixYa
Dec 23, 2009 | MSI PM8M-V Motherboard
Msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+NEO&table=download
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link; http://www.msi.com/index.php?func=searchresult&keywords=MS-6702&table=download
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link; http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Cheers!
Mike
Oct 24, 2009 | Computers & Internet
Need to know where the black yellow speaker wire gets plugged into a msi k9a2 platinum
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
Apr 23, 2008 | Intel Motherboard
Intel Motherboard Logo
707 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
