Question about Samsung HT-Q100 System
Samsung home cinama
Hi I have linked it all up and working fine when playing the DVD but no sound is coming out when the TV is on the DVD has a new scart lead so cannot link the sky box have tried running the red and white aux cables from the sky box to the dvd player but still no sound whilst the sky is on. Help !!
    New Friend:
  • 99 Answers
Most likley your scart cable is the culprit, check whether the scart cable is the AV I/O type. And also better check the audio settings of the DVD player. Hope u hook up the speakers correctly. Cheers, Rifaa
Posted on Sep 04, 2007
SOURCE:
I have the Samsung HT-C550 home theater system and a Sony 42" HD TV. The two devices work well when playing a DVD but when I watch TV I can't get the TV sound through the home system. I am...
Try this:
Purchase a 3.5 mm jack (it will have a smaller connnector going into the TV and Red and White connectors on the other end).
Pull all the other cables running into the Blu Ray player out so that you are only left with the HDMI Cable coming from HDMI Out (DVD) to HDMI/DVI In (TV), along with the 3.5 jack.
You will be able to play the TV sound through the system.
Jan 13, 2011 | Samsung HTC550 Theater System
I have a panasonic dvd home theater sound system SC-HT880 and i have just upgraded my tv from a Samsung 42 in Plasma to a Samsung 50 in 3D ready tv and i can not get the dvd payer to work in tv mode by...
Hi
Have you resolved this issue yet? I am in a similar position. recently upgraded my TV to a flat screen, also purchased a Blu-Ray but the SC-HT880 is now useless. How can I use the surround sound to work on TV? do I need to purchase an Amp?
Dec 31, 2010 | Panasonic SC-HT880 System
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
Hi,i have a samsung ht-txq120 home cinema system,dvd films freeze sometimes when playing,can you help
Hi I had this problem.
Aent it back to supplier had something replaced and it worked ok for a month and started doing the same thing so i went onto Samsungs website and downloaded the firmware onto a USB memory stick and loaded it onto the system, has been working fine for the last 6 months here is the link
http://www.samsung.com/us/consumer/tv-video/home-theater/home-theater-systems/HT-TXQ120T/XAA/index.idx?pagetype=prd_detail&tab=support
Oct 15, 2009 | Samsung HT-TXQ120 Home Theater System...
No sound coming through system when tv on but works fine with dvd
you need to link the tv sound out to the aux/tv in on the dvd. Or if the scart connecters on the rear of the tv have a 2 way arrow, showing input and output on the one scart socket (usually scart 2) and the dvd supports scart sound in use that.
Then select the source on the dvd that coresponds to the conecter used.
Jun 15, 2009 | Samsung 1000W 5.1-Ch. Home Theater System...
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
No sound on tv but have sound on dvd and radio through my home cinama i wont to listen to the tv through the home cinema but cant get it
What is the source of your TV signal? Cable? Sattellite? Are you using the receiver in your tv or a cable/sattellite receiver box?
Whatever the source of your TV signal - it will probably have several choices of output. Make sure you have that connected to the tv-input on your home cinema. Then make sure that when TV is selected on your home cinema that the audio format specified matches what you hooked up i.e. analog (the red and white cables), optical or coax.
Oct 21, 2008 | Samsung Audio Players & Recorders
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Samsung HT-Q100 System Logo
145 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
