I cannot connect to internet with my wireless usb adapter
I am using linksys gateway one system is connected the next system is not connecting the system in which i am using 3com office connect wireless usb adapter it is showing disconnected state
  • 3 more comments
  • Anonymous Dec 26, 2007
    unable to get connectivity through given WIFI of linksystem model no WUSB54GC pls advise what is maximum code length to be used for desktop users
  • Anonymous Feb 11, 2008
    We installed the usb and the green light went right on and then off. The IT guy said it was a faulty usb....I would like to send it back either for repair or replacement.
    Patti Guilford
    530-412-2075
    [email protected]
  • Anonymous Nov 18, 2008
    cannot find IP
  • Anonymous Mar 26, 2014
    cannot make a connection from my wireless 1450 adapter to a nexuslink 5361 it shows the connection but never connects to the internet
    cannot make a connection from my wireless 1450 adapter to a nexuslink 5361 it shows my internet connection it try to connect but never does
I have the same problem , can't get rid of it ... My wireless router is like 1 meter away from me and it can't still get the signal . I think the problem is in software .
,Regards
Posted on Aug 30, 2008
    President:
  • 2,961 Answers
You need to get into your routers settings and make sure that DHCP is enabled to automatically assign ip addreses and also go to the properties of your wireless adapter and ensure obtain ip address automatically is checked. Turn off any WEP or WPA security until you have all the connections, make sure that the adapter is on the same wireless channel as your router and that all the pc's are on the same network workgroup eg WORKGROUP or MSHOME. It may be as simple as right clicking on your wireless adapter icon in control panel>network conections and select connect.
Posted on Sep 04, 2007
SOURCE:
I previously was able to connect to internet and suddenly it no longer will connect- is there anything I can try to troubleshoot this? I am running Windows XP
are you sure you are using the right protocol in aqccordance with the information from your provider.. WEP or WPA-PSK?" and the right number to open the gateway?
If the newtwok drops out, sometimes this information is lost and has to be reinserted. If you uninstall linksys and remove the usb and then reinsert it, does it flash and become discovered?
Also make sure you have set up wireless network in XP
If a wrong protocol is inserted Linksys will often report.. Connected to the Network But internet gateway not found... If you get that message then ewither your protocls are incorrect or you have not set up the network correctly. your ISP should be able to guide you through this by phone support.
Please rate my help++++Thanks for using FIXYA
Aug 04, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
My system was working fine one day. The next day, it won't connect to the internet, saying that Windows can not manage my linksys connection. I have a Dell PC using Windows XP Service Pack 3
There are two solutions that you can try first
Perform system restore to the earlier date that connection working fine
OR
Re install the driver of the wireless adapter
If you need further help please post.
Good Luck
Jul 06, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
How to start over with a secure connection with a wireless
1)Press the reset button on the back of the router.
2)Open your browser and type in 192.168.1.1
3)Then login as administrator and set your configs.
May 24, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Do i have to have a linksys router to be able to use usb adapter?
No you do not, but you do need some form of a wireless router to make that Internet connection wireless. Depending on which modem you have that connects to the Internet, you might already have a wireless router.
Feb 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Jul 25, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Router connecting to Linksys USB adapter
to confirm if your Network adapter's assigned IP, subnet, Gateway & DNS
  • Start > Run > cmd
  • at cmd prompt type: ipconfig /all
  • look at the parameters given to your Network Device that is connected to the router (IP, Subnet, Gateway & DNS Servers.
  • Verify those addresses if they are reachable by pingging. Check your IP, Gateway, then check for the DNS Addresses. Type cmd prompt: ping ip_address << do not omit the periods between the numbers.
  • See if there are replies from those addresses. if you get Request timed out, tell us here which part you get one. if you can receive a reply from those addresses (gateway & DNS Servers) definitely you are already connected to the internet. Just check your Browser's connection setting.
Jul 06, 2008 | Linksys Computers & Internet
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
Internet conections
you will need either a usb 54MBPS or 108MBPS wireless adapter of any make that will connect to a usb port or a pci wireless card to fit in the pc tower on the motherboard.
Oct 06, 2007 | Linksys (WUSB54GCU) 802.11g/b Wireless...
Open Questions:
Computers & Internet Logo
3,465 people viewed this question
Ekse
Alun Cox
