Pc is constantly switched on & will not boot up
I had a fault & the mains lead shorted out going in to the back of the PC i have replaced the lead & now when you plug it in to the wall socket the pc is not booting up & the boot up light & on of switch are constantly flashing i have replaced the power pack but this has not cured the fault the screen is black can you help pls cheers dave
  • wakka Sep 04, 2007
    thanks for the info is it had to replace the motherboard ???
    cheers for the info its been a geat help
    President:
  • 2,961 Answers
You may also have a fried motherboard unfortunately as the flashing light can refer to a power supply unit problem or motherboard fault
Posted on Sep 04, 2007
  • andrew pester
    andrew pester Sep 04, 2007
    No, as long as you get one that suits your processor, but you will have to use your XP cd to repair windows, not re install ,as the system wont boot because of a major hardware change, althogh you may be lucky if it's an exact replacement.
  • andrew pester
    You seem to have rated the wrong post
    Problem Solver:
  • 6 Answers
Most likely your motherboard is the problem about the only option is to replace it
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
Will not power on
Try to change your power supply.
Jul 14, 2011 | Medion M3 Composer 5200 PC Desktop
No power at all, np lights come on and well nothing!
No power and power LED does not light up, this indicates either the mains power is off or you have a faulty power lead. Test the mains socket and the mains power lead.
If these are OK then the fault most likely a faulty switch mode power supply. Remove the switch mode power supply and get it tested at your friendly computer repair shop OR borrow a power supply and insert it into your PC to see if it now boots up.
If it boots up the replace the power supply with a new switch mode power supply with the same total wattage or higher wattage.
Apr 01, 2011 | Packard Bell iMedia SL 9553 (P660401806)...
Sony kv32fq70 led blinking 2 times
Hello
It is due to the self fault diagnosis function built in with every latest Sony sets. According to the faults, and section, number of blinks will deffer in numbers. In your set, two blinks indicates that there is some short circuit occured due to some component faults inside the circuit board of your TV. This fault is calle [OCP], Over Current Protection.
It may be sometimes due to the fault of shorted LOT [Line Output Transformer], or its driver transistor has a short between its collector to emitter leads, or any capacitor shortage, or any kind of short, which causes heavy current flow from the regulated power supply section of your TV.
You just start with the horizontal output transistor stated above. It can be located very near to the LOT. usually screwed onto a metal plate, to radiate heat from it while it works. You just resolder it out from the board and check with multimeter, preferably an analogue one, and measure its collector to emitter resistance, both forward and in reverse mode. If it has a short you will get almost full deflection in the multimter movement. If it is so, you have to suspect the LOT said above too, because horizontal output transistor failure indicates some LOT trouble also.
If so just replace the transistor with same type and number, and switch on the tv just for a short period, say 3 or 4 seconds, and feel the temperature of the replaced transistor with your bare hand, after switch-off the set by unpluging from AC mains outlet. If it overheats, there is some overload, and it is mainly due to the above said LOT. There is an other chance too for this fault. That is deflection yokes' winding short. It is very rare, 1/1000 may occur. Normally an LOT short is found in most cases. If the transitor overheats as said earler, replace the LOT also.
Without the transitor, you just connect a filament bulb of 220v 100W or so, between the main positve rail of the DC supply voltage 130vDC. If the bulb glows constantly, you can make sure that the short is due to lot fault.
An other posibility is shorted secondary filter capacitor and retifier diode. The 130VDC is derived from the secondary side of the SMPS transformer at the power regulator section. There is a rectifier diode and an electrolytic fulter capacitor, normally come to the value of 220MFD 160V or so. If the capacitor gets shorted, it will give a heavy load as stated earlier. Check these components also. OK.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
POWER UP AND IMMEDIATELY POWERS DOWN PC WORLD SUGGEST THIS IS A BLOWN MOTHERBOARD HOW MUCH IS A FIT MYSELF NEW MOTHERBOARD
This could be a power supply fault,check the volts on the red,yellow and earth lead(black)THE RED LEAD =5VOLTS
YELLOW LEAD=12VOLTS.WHITE=-5VOLTS
BLUE=-12VOLTS,PURPLE,=+3.3VOLTS
BROWN=+5VOLTS VSB
BLACK=GROUND.
Diconnect the pc mains plug from the computer.
Disconnect the power supply leads from the motherboard,and switch on and check the volts on all leads of all those I mentioned.If these are present when they are not connected to the main board,then the problem is with the motherborad,most likely the bios chip is faulty.This chip kicks starts the PC into coming on.Failing this send the PC back to where you bought it and let them fix it.
IT COULD ALSO BE THE MAIN ON OFF SWITCH AND THE CABLE ITSELF FAILING.CHECK THIS WITH AN OHM METER ON X1 OF THE RESISTANCE SCALE.DISCONNECT THE MAINS PLUG FIRST.
Aug 07, 2010 | HP Compaq Presario F500 F700 and G6000...
Boots up but only runs for about a minute. Then fan runs at full speed constantly with no video. Also front panel popwer switch appears shorted. i.e as soon as you plug in the PC starts
Very well could be overheating or powersupply problem. Most Definately Hardware related. You can try opening up the case and blowing air into it from compressor. (Make sure to do this outside away from clean items). Also, check CPU fan and heatsink to make sure fairly clean. CPU fan may also be old and need to be replaced. Don't put case back on and try again. Look at CPU fan to see if moving (or struggling). If computer stays on longer then CPU fan most likely the problem. If off in same time as before then most likely the main power supply problem, in which case the only way to check this is to replace the power supply. Hope this helps, Best Regards,
Nov 09, 2009 | Acer Aspire T310 PC Desktop
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in...
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Oct 22, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Hi, I have a problem with my Enermax Blue Viper CS-718-B, bought in 2006. When pressing the start button, the light and fan are working very short, or I get a peep, but the computer is not booting. Only if...
Your computer either has a fault with the power button in which you can request off the manufacturer a replacement (may cost money depends on warranty) or you do not have enough power for the computer components. Try removing all the peripherals except from screen, keyboard and mouse and then try booting. If it works then you dont have a large enough power supply for all the equipment you have. If it still does not work then it could still be a power supply (PSU) fault in which you can take the psu to your local computer store and they can test it for you.
hope this helps
Oct 08, 2009 | Enermax (CSXSEG718SNP) ATX Full Tower Case
Pc wont power up
Is there an on off switch on the back out the computer next to the main power socket? If so move it to the on position.
Check the mains lead and make sure it is firmly inserted in the socket.
When you press the front panel on button and it doosn't boot up and there is no light indicating power, then you have a faulty switch mode power supply.
Remove the switch mode power supply and replace it with a new one with the same wattage or greater wattage.
May 07, 2009 | eMachines D3415 PC Desktop
Computers & Internet Logo
963 people viewed this question
Alun Cox
David Payne
David Payne
