Using the pm63005dvd laser lens cleaner:
Why won't this darned cd work in my rom? is it because it isn't a dvd, but a cdw\r??? and if so, what do i do to make it work< without having to shell out $$ i don't have to get the dvd rom? please help soooooooooon. thanks soooooo much for your time and knowledge. vish
  • Anonymous Nov 14, 2007
    doesnt read disc
  • 1,006 Answers
Exist some software but i will NOT recomended you to use couse it will work just few days and u have to buy new cdw/r.ok?
Posted on Oct 15, 2007
My CD rom is not working
No matter what type of laptop you own or how you use it, the CD-ROM or DVD drive is an important part of the unit. With the CD or DVD drive in place, you can play your favorite music or watch your favorite movies, so when that CD or DVD player stops working it is important to get it back in service as soon as possible.
1.Locate the bypass hole on the CD-ROM drive. There is a very small hole, generally located underneath the eject button, on every CD-ROM drive. Unbend a paper clip and insert it into the hole until the CD tray pops out.
2.Remove any CD that is in the tray and replace it with a CD laser lens cleaner. These laser lens cleaners are available at computer shops and electronics retailers.
3.Run the laser lens cleaning program, then try to play a CD again. If that CD fails to play, replace it with another CD and try again.
4.Shut the computer down and remove the AC power cord if cleaning the laser lens does not resolve the issue. Turn the laptop upside down and slide the battery release lever to the unlocked position.
5.Remove the battery and set it aside. Then locate the screws that hold the CD-ROM drive in place and remove those screws. Slide the CD-ROM drive out of the bay, then slide it back into the bay until it snaps securely into place. Replace the screws that hold the drive in place, turn the laptop back on and try to read the CD again.
6.Log on to your computer and right click on the "My Computer" icon. Select "Properties" from the menu and click on the "Hardware" tab. Click the "Device Manager" button and expand the CD-ROM section. Right click on the CD-ROM and choose "Update Driver" from the menu to download and install the latest device driver from the CD-ROM manufacturer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Lenovo 3000 Y410 Notebook
My DVD/CDW combo SH-M522C can read CD but can't read DVD!!!
try to run the Microsoft Fix it option to delete the upper and lower filters and if this does not work, update the firmware and try to use a lens cleaner. if nothing works including system restore, it might be time to get a new drive. hope this helps
Apr 16, 2011 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
My cd rom does not read dvds
you might as well check your Toshiba PC Laptop if your CD-ROM can read DVD's .. Look at this figure... ryanpajaro20_6.jpg
There will be a hint for you to check the Optical drive if it has the DVD label. Otherwise , consult Toshiba for it...
Mar 18, 2011 | Toshiba Computers & Internet
My tsst corp cdw/dvd ts-h492a dose not recginize dvd-r help
This could be due to various reasons. First check whether the inserted dvd-r is working with any other system? if yes, Clean the drive lens using lens cleaner CD/DVD. Still you are facing the problem, then there could be a problem with the lens allignment and need to repair the same with the help of local expert engineers or nearest service center experts or buy a new Drive if repairing cost is more than the new one.
Revert back for more assistance and give your valuable feedback/rating for the soluton provided.
Thank you for using Fixya.
Mar 01, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
I need to re-install cdw/dvd rom... but my current dvd rom is not functioning or not reading any cd or dvd? Thanks
You need to change the Lens if it ain't reading. Try cleaning the Lens with A Lens Cleaner. If it doesn't work still Replace the Lens. My Suggestion would be to buy a new Drive as once it starts giving problems they occur frequently.
Feb 24, 2010 | Computers & Internet
Cant read DVD in my DVD Rom
you can try a laser lense disc cleaner , something similiar to
http://www.amazon.co.uk/Scotch%C2%AE-Laser-Lens-Cleaner-DVD/dp/B00006HZ2Z
I think there are better branded ones.
If that does not work then the laser lense for the dvd is not working / broken so will be easier to replace the dvd drive.
Apr 23, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
My tsstcorp cd/dvdw sh-w162z wont play wont rip and burn.
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 16, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
I hav lg dvd writer it plays cd but dvd what to do
That is because of a dirty or defective lens. When you have a lens problem the unit may still play CD but not DVDs.
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
Feb 15, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Dvd read
This is becaz of the lens which is used to read the data frm the Disc. The weak (not damaged) lens may read CD but no DVD.
Try changing the lens........
Dec 15, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
