Question about Sony DAV-SC5 System
Component Video Connection
I have connected the Component Video outputs from the DAV-SC5 to my TV, but where do I take the audio from in case I want to use the sound from the TV as well?
  • hbpuri Sep 04, 2007
    Thanks, sandrew - i AM getting the sound from the 5.1 surround speakers, but since there is no audio being fed to the TV, the speakers on the TV are silent when playing DVDs. The TV does have connectors for Audio IN (L & R), but there are no corresponding Audio OUT connectors on the DAV-SC5 that will work in conjunction with the Component Video Out connectors.
    I already have connected the TV Audio OUT to the DAV-SC5 so that I can listen to the TV sound thru the surround speakers.
    No scart connection facilities on either the TV (Sony KF-55E200A) or the DAV-SC5. The TV has Audio In (L/R) sockets located alongside the Component Video In (Y,Pb,Pr) sockets, but where do I get the Audio (L/R) FROM, since the DAV-SC5 has no corresponding Audio Out (L/R) along with the Component Video Out (Y,Pb,Pr) sockets.
    President:
  • 2,961 Answers
What you have done is you are sending a component video signal from your system to your tv and the sound i assume comes through the 5.1 surrond speakers. The DVD's you play the sound would naturally come from the 5.1 surround speakers, unless your instruct the dvd player to send the sound to the tv in which case will only be played as stereo. you will need inputs on your dav system to take sound from your tv outputs or digital box by way of red and white phono leads or a digital/optical input if you have them; so as to play the sound from cable tv or sattelite tv through your 5.1 surround speakers.
Posted on Sep 04, 2007
  • andrew pester
    andrew pester Sep 04, 2007
    Although putting the sound through the tv will be defeating the object of surround sound but if you have a scart socket you can buy a lead scart one end coming out to phono and video the other end to put in your tv or scart to scart if you have a spare scart socket on your tv.
  • andrew pester
    sorry, yes you have used the component leads the sound should come through the tv as its built in with the HD leads you have used as long as you have component in selected in the tv screen menu and auxillary or whatever is used to output sound from your dav, but you would useually use the dav as an output for sound not inputing it into somewhere else.
SOURCE:
I am looking at connecting multiple components with DAV HDX275 Sony surround sound system. But it appears that there is only one red/white/yellow jack on the back of the unit. Any suggestions?
hi,
check one more time. your player DAV HD 275 have component video output. three sockets near the yellow, red, white sockets. Named Y, PB/CB, PR/CR.
remember on thing when you connect the component video, be sure to connect the red to red, green to green and blue to blue. if not you will not get the correct video. will become out of sync or black&white
ok
Jan 24, 2011 | Sony Audio Players & Recorders
Sony DAV-SC5 not playing 5.1 through the optical input from sky/blu ray
The DAV supports Dolby Digital® DTS 5.1 audio. Make sure your blueray movie has 5.1 track and is outputting to the DAV.
Jan 26, 2008 | Sony DAV-SC5 System
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
DVDs play in black and white
Try use connect your dvd player with just RCA(composite video) and see if you get regular color picture.If so,you need to go to the system menu to check the video output and see if it is under R Pr Pb-component video setting?If not,be sure to change it to component video setting AND use component video cable to connect to your TV unless your TV don't have this connection.
Joe
Feb 03, 2008 | Sony DAV-C990 System
Audi but no picture when cable box conected through DAV-X1
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
Dec 25, 2007 | Sony DAV-X1 System
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
Sony DAV SC5 Home Theatre System - NO picture only sound when DVD / VCD played
Have you set the tv type (PAL/NTSC/Multi..) or the component type (RGB, YUV, etc.) suitable for your tv? If not, go to the main menu of your Home Theater System then check it out.
Apr 19, 2007 | Sony DAV-SC5 System
Sony DAV-SC5 System Logo
173 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
