Question about Emjoi AP98R Epilator
110V plugged to a 220V outlet
Hi! I bought my Emjoi Ap98R epilator in the states and when i transfered to the philippines, the standard voltage for electric is 220V. I accidentally plugged it so now it doesn't work. Can this be repaired? How? Please help coz i really love this item.
  • 625 Answers
Your unit is toast! sorry time to get a new one! repair parts will cost more than a new machine.
Posted on Sep 07, 2007
SOURCE:
I need an AC adapter/ Power suppply for an Emjoi AP98R epilator
You need a compatible NiCad charger, I opened the AP98R and it contains 2 AA rechargeable NiCad 1.2v 700ma batteries.
Basically any NiCad charger that outputs the same voltage and ma will work.
Apr 11, 2013 | Emjoi AP98R Epilator
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
How to change Emglo air compressor from 220v to 110v. Compressor is running at half speed when plugged into standard wall outlet. I bought the compressor new in the early "90's" and since then...
Hi Pete,
On the side of the motor on the label should be a wiring diagram. The diagram will tell you how to wire fro high 220v and low 110v ...
If the nameplate is single voltage only then the motor cannot be rewired for the lower voltage...
Also check the motor RPM nameplate as compared to the others...you may have a 1725 motor and the newer ones a 3450 motor...that would give them double the RPM's if the gearing or pulley sizes are the same...so.. if you have the right voltage and the RPM's of the motor are the lower, then you possibly could change the pulley sizes to speed up the compressor...
Lots to check and think about...
heatman101
Mar 11, 2011 | Dewalt Air Tools & Compressors
110v lcd tv was plugged to 22ov outlet
Hello nik286, hi, check first the label at the back of the TV, look for a voltage input something like a 90V-240V, if you see this, its an autovolt system, this type of power supply input is standard nowadays. Assuming your asking what would be damage, this could be anything from the fuse, thermal resistor, rectifier diodes, and the regulator IC of the power supply board.
Apr 12, 2010 | Sansui 19 in. LCD TV
Can you get replacement heads for emjoi body bare ultimate?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 20, 2009 | Emjoi AP98R Epilator
Are there any replacement heads out there?
If you go to http://www.jr.com/emjoi/pe/EMJ_AY5S/
they have your razor and it's a rechargable one for only 34.99 plus 6.99 shipping but you might want to check out that sight
Apr 16, 2009 | Emjoi AP98R Epilator
Braun epilator usage in different voltage
You will need a power step down transformer.
220V to 110V
CLICK HERE to see an example.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Braun silk-epil 5270 Epilator
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Emjoi Head AP98R
i have the same problem, I have had this replaced once already. It has just happened again for a second time!! Contacted Sunbeam and they do not sell parts and will not touch as it is out of warrantee!! Sorry
Dec 14, 2008 | Emjoi AP98R Epilator
Emjoi AP98R Epilator Logo
553 people viewed this question
Top Emjoi Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you an Emjoi Health and Beauty Expert? Answer questions, earn points and help others
