Question about Nokia 6233 Cellular Phone
Headset feature my 6233 has somehow turned on the headset feature without the headset even being connected and i don't know how to turn it off
Headset base of the handset is short due to contact with water. open the hanset and cleanthe base with ctc
Posted on Sep 04, 2007
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Unlock code for nokia 6233
Hi, You can get the unlock code for a Nokia 6233 from www.wickedunlock.com/nokia-6233/rs11wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 6233,
1 - Switch on your Nokia 6233 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6233.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6233 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6233 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Aug 26, 2012 | Nokia Unlocked Cell Phone 6233
The radio on my nokia 6233 is not comming on, even after connecting the headset. help
first restore factory setting after it not work its hardware fault.......100%
Feb 10, 2011 | Nokia 6233 Cellular Phone
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I have Nokia 6233 and it's Headset symbol is displaying on the screen even no headset is connected. It was accidentally turned on. I am able to talk while incoming and outgoing calls only when...
you got a chort cut in the microfone contact,
phone indicates that the headset has been plugged in,and cut of the circuit to the phones microfone.
1)open your phone and clean the microfone connectors and the goldplated surface on the mainboard.
2)if your phone has been very wet, the short cut can be in the microfone.( change microfone)
If solution 1) doesnt help,
try solution 2) and change microfone.
This kind off problem is an common microfone issue.
Hope this helped, Please vote!
May 03, 2010 | Nokia 6233 Cellular Phone
Nokia 6233
Its not a virus. Its a physical damage. Kindly get your phone checked by the nearest Nokia care.
regards
Sandeep
Oct 12, 2009 | T-Mobile NOKIA 3660 HS-37W Bluetooth...
Problem with the talking.
Not sure what model/make you've got but what you describe is called the VOX feature. This normally needs to be turned on or will activate automatically if a headset/mic is plugged in. How it works is that the mic will pick up initial noise of you speaking and make the connection. Normally it can be set to turn off after a period of silence.. But as I said, without knowing the make or model I don't know if your radio has this feature or if it's a fault.
Oct 06, 2009 | Radio Communications
How to format nokia 6233 mobile phone
switch off your mobile first. Hold the following 3 keys simultaneously. Call button(green button), * and 3(number button)
With there 3 keys holded by u, simultaneously
switch on your mobile.
Feb 26, 2009 | Nokia 6233 Cellular Phone
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
6233 switch on
No the only possible way to turn on the phone is by connecting it to the pc and see if it automatically turns on hope to of been of help
rabbit07
Feb 24, 2008 | Nokia 6233 Cellular Phone
Nokia 6233 Cellular Phone Logo
261 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
