Question about Intel Motherboard
Games do not work properly
I purchased a new machine with 946gz chipset.All the games which require graphics do not work properly.Please suggest me the solution for it.
    President:
  • 2,961 Answers
The graphics chipset is onboard and wont support the type of rendering and 3D that some of you games must require, you will need to fit an AGP fraphics card to get the best from your games along with DirectX9b if youve not already got it installed.
Posted on Sep 04, 2007
SOURCE:
Computer dell latitude D610 built in 2006 replacing the viedo card how too's and also what can I do to mabe upgrade this veido card? and dose anything else need to be updated at the same time as the...
Sorry Jimmy, the Dell Latitude D610 Notebook PC uses Integrated Graphics.
There is no graphics card to upgrade.
Your Dell either came with a form of the Intel GMA graphics chipset , or the ATI Radeon Mobility X300 graphics chipset.
http://support.dell.com/support/edocs/systems/latd610/en/ug_en/specs.htm
Either/Or
The way Dell states it, (And also this is for a LOT of laptop manufacturers), is that you have either the option when purchasing, of having an Intel GMA chipset for graphics, or discrete graphics of the ATI Radeon Mobility X300, for graphics.
Discrete being the word that fools people. Makes them think it has a dedicated, removable graphics card, when in reality it is a graphics chipset soldered directly to the motherboard, and is not upgradeable.
Primer:
GPU
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
Essentially the 'graphics engine'.
A GPU can be installed directly on the motherboard, (Integrated Graphics), OR installed on a removable graphics adapter card. (Graphics Card is shortened for graphics adapter card)
Integrated Graphics borrows from the system resources. The Processor and Ram Memory.
This is why programs, for example games, that use a lot of graphics 'power', do not perform well on a computer with Integrated Graphics.
{Read - programs that use a lot of graphics power. Such as some of the newer games. Integrated graphics, depending on what graphics chipset it is, CAN run some games. Ones that are not very graphics intensive}
A dedicated graphics card has it's own processor, and graphics ram memory. Does not need to borrow from the system resources.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The graphics chipset in your Dell Latitude, is mounted to the motherboard with a BGA surface mount.
Ball Grid Array
http://en.wikipedia.org/wiki/Ball_grid_array
To explain the BGA surface mount;
Let's use the older Intel Pentium 4 processor that uses a Socket 478 processor socket.
The bottom of the processor has contact pins. (478 of 'em)
The processor socket has matching socket holes for the contact pins. (478 of 'em)
With the BGA surface mount there are no contact pins. In place of them are Solder Balls.
There is no socket, or socket holes on the motherboard.
There are Copper Pads.
The graphics chipset is set into place with the Solder Balls lining up on the motherboard's Copper Pads.
Then heat is applied at a specified temperature, and length of time.
The solder balls melt which solders the graphics chipset to the motherboard. (To the Copper Pads)
Removal and replacement is properly performed with a BGA Rework Machine.
Costly, and not something you'll find a local shop performing.
{The machine is costly, and the operator needs to be S-K-I-L-L-E-D. Cost of having a chipset replaced is Ouch!}
There are two ways you can upgrade your graphics.
1) If you have the motherboard model with a form of Intel GMA chipset attached, you can purchase the motherboard that has the ATI Radeon Mobility X300, and install it.
2) Purchase a laptop with better graphics.
{Not trying to be snide}
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2011 | Dell Latitude D610 Notebook
I CANT RUN NFS CARBON ON MY PC ITS A DELL GX280 WITH 128 MB BUILT IN VGA CARD. WHAT SHOULD I DO? I mean can i run it on the same VGA. Coz it runs NFS Most Wanted and GTA San Andreas Smoothly....
Video Card: A video card with 64 MB memory and one of these chipsets is required:
NVIDIA GeForce3 / NVIDIA GeForce4 (Ti series only) / ATI Radeon 8500.
Laptop versions of these chipsets may work but are not supported
Aug 06, 2009 | Dell GX280 Optiplex 2.8GHz Desktop...
I have intel-945GM express chipset, and i need to play a game that needs shader model 3 please advice
firstly you need to have a pci express graphics card inorder to play new games. Intel chipsets are NOT for playing games!! You should get at least a Nvidia 8600gts or ati 3650 or similar to game properly- presuming that you have a pci express slot. Be warned that if you get a new graphics card dont go by the series eg, 8 series or 9 series- a 8600gts is better than a 9400gt. A nice graphics card for the money is the nvidia 9600gt. Good luck upgrading
May 05, 2009 | Computers & Internet
SAQI
If you are using the on board graphics this will cause problems due to your 1 gb of ram being shared with the graphics and other things , for most of todays games that will cause many problems, I would suggest getting a video Card or playing older games that the on board graphics can support. The restart usually is a sign the the graphics capability is to low for the game, altho you can tweak your computer to some extent you will always still have problems. Now adding extra ram can always help but still i would recommend getting a video card first that your computer supports.
Hope this helps, let me know if i can further help,,,,larry
Dec 12, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Playing high graphics games on acer aspire 4315
Check the requirements printed at the back of each game. this will tell you if the game runs. If some game is slow try disabling the antivirus while you run the game, remember to restart antivirus afterward.
Do not use software accelerator, majority of them are useless, some of them carries malaware and viruses.
Aug 13, 2008 | Acer Aspire 5100 Notebook
Intel graphics card
Hello there.
Unfortunately Intel drivers have some bugs in them which means it will not support Hardware T&L correctly. This means that intel graphics chips are not recommended for any new games and many old ones. Some Intel chipsets support more than others, unfortunately yours doesn't.
You can see here which chips support some parts of hardware Transform + Lighting here at http://www.intel.com/support/graphics/sb/CS-011910.htm
An entry level AMD/ATI radeon or Nvidia graphics chip would be more suited to occasional gaming on a laptop system.
Jun 28, 2008 | Intel Computers & Internet
Mother board problem
sounds like video card driver issue...ensure driver is correct by looking at video card in device manager. Also ensure that system interrupts are being allocated properly.
Jul 28, 2007 | Intel Motherboard
MACHINE GETS REBOOTED WHEN USING HIGH GRAPHICS
Assuming you are running Vista; you can find out what the problem may be by going to control panel> system & maintanence> administrative tools> event viewer>windows logs. look in all the catagories to see if there are any clues as to your problem, but normally i would say it's a graphics driver error or processor overheating, especially if you have onboard graphics and not a seperate dedicated graphics card.
Jul 13, 2007 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
