Question about Intel SYNTAX S651M SIS651 mATX (SYNTAX S651M SIS651) Motherboard
Computer wont boot up
I took put another harddrive from a computer into my computer, and when i removed it, my computer wont boot up! It just keeps on beeping.
    President:
  • 2,961 Answers
When you fitted the hard drive, you must go into the bios and make sure your new hard drive is listed as it will be looking for your old one, there should be an option to press an 'F' key to detect hard drives, and also ensure the date and time is set correctly. Assuming that the new drive is the master and is set as master, unless it's a seondary drive and should be set as slave if on the same ide cable. If the hard drive is from another pc with an operating system already on it then the pc wont boot as the information already on the drive refers to another pc motherboards drivers and all the component drivers; so you will need to repair your windows operating system by way of your XP cd.
Posted on Sep 04, 2007
  • 32 Answers
Hi, If it is a continuous beep then it a RAM error not a harddrive, so you try to change the ram slot if it doesn't happen change the ram thanks arun
Makes beeping noise
Remove and reseat the memory card(s).
Jun 09, 2013 | HP Hewlett Packard Pavilion 23-1030 23"...
Y does my computer keeps beeping and it wont turn on
How many beeps are you getting and notice whether they are long or short beeps? Beeps tell the technician what is going on with the computer. It could be a number of things going on with the motherboard, or things that attach to the motherboard.
Try removing the power cord, opening the case, then taking out one of the memory chips and sitting it aside. Then plug the computer back up and see if it boots. If not, move the memory chip that is in there to the next open slot, then try booting again. If it still does not boot, remove that chip and set it aside and get the chip you already had set aside and move it into the memory slots trying to reboot. If it boots, mark an x with a ink pen on the chip that is set aside, it is probably bad, then put it into the computer's open memory slot and try rebooting. If it fails to boot you know the cause is the chip with the x on it.
Mar 28, 2012 | Dell Inspiron i5602128NBK Desktop PC Intel...
Hi, I have a dell dimension 5100. I inserted a 1gb ram but it was the wrong one. I took it out and replaced it with the old ones. Now the computer doesn't boot properly - turns on but doesn't load...
Remove all the memories and insert them again, make sure you insert them in the proper way as the slot is keyed.
Memory issues can be identified by the beep sounds.
If you have more than one memory, remove one and insert only one of them and try to boot.
Hope this will help.
Aug 19, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
I put a harddrive from my dell computer in my gateway dx200s. It booted up but I could not verify profit key. So I replaced the dell harddrive with the original gateway drive but now it wont boot. beeps...
all you need to do is put back the hard drive to the gateway, theres like a finger print that block the hard drive to come on but if you put back to its own i will come on...if you want to make it work in the dell you need to install a fress os...period...
May 01, 2011 | Computers & Internet
T500 lenovo kepps beeping and wont turn on it just keeps beeping. i turn it off i took out the batter and still the beep is there and the computer wont turn on
remove the power supply and battery then remove the memory module, clean the memory gold contacts. a regular pencil eraser will do. return the memory then the battery.
Apr 19, 2010 | Lenovo ThinkPad T500
P4M800 Wont boot
Hello there:
please try this first unplug the power to the computer
next open the case and unplug all of the cables and cords that connect to the harddrive cd rom ect ect
now locate the power supply cord that goes to the motherboard and disconnect
press the power button on the computer for 20 seconds and also if you have a reset button press it . what this hoes is releases any stored esd that is in the computer ..
now plug in the power supply back into the board and plug in the power cord and try to boot the computer and see if it comes on if so great just plug in the cords to the cd rom harddrive ect ect and than reboot and you should be ok
Sep 23, 2009 | Biostar P4M800-M7A Motherboard
Monitor not responding to computer
better check the continuity of you cables/connectors.
May 28, 2009 | E-Machines eMachines Desktop PC
When i Power up my Laptop it wont boot!
Ooooh! That was not a smart thing to do.You may have shorted something out.
Try this:
Make sure it is unplugged.
Remove the battery.
Remove the hard drive again.
Hold down the power button for at least 60 seconds.
Replace the hard drive. Make sure it is seated properly.
Try booting.
If the power light comes on but the laptop will not boot you may have fried your hard drive.
Apr 05, 2008 | Compaq Evo N1000C Notebook
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
Intel SYNTAX S651M SIS651 mATX (SYNTAX S651M SIS651) Motherboard Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
