DVD recorder I have a Goodmans GDVD303RW dvd recorder. There is a label on top of the unit that states the dvd tray willnot open until first installation has been completed. During the first installation I had a power outage which interrupted the process....and the dvd tray will not open. The dvd recorder was a gift bought in the UK......I live in South Africa so returning it is a slight problem.
SOURCE:
SOURCE: sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Posted on Jan 18, 2007
SOURCE: DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Posted on Mar 30, 2008
SOURCE: Need to play region 1 DVD in region 2
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail [email protected]
Posted on Jul 25, 2008
SOURCE: LG HDD DVD RH1757 region code problem
Press 'setup' on the remote
Scroll down to the 'lock' icon
Press 0 seven times - you'll get onscreen confirmation.
Posted on Nov 08, 2008
quang123
  • 107 Answers
SOURCE: Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Posted on Dec 09, 2008
Non si apre il cassetto e sul display compare la scritta "blocked"
Firstly if there is a dvd stuck inside the machine and it won't eject then try the following: Turn off the power at the plug socket and remove the plug then look on the underside of the machine. On some Philips dvd players there is a plain white label below where the dvd tray sits under this label is a slot which gains you access to the manual release. If there is a label and slot gently pierce the label using a small screwdriver and push the screwdriver gently in until it stops then move it from right to left. This action moves a lug sited under the drive unit, this lug is the manual release for the tray. You will then see the tray open and will be able to remove the disc, moving the lug back will close the tray.
But this problem on Philips dvd players and recorders is a fault with the dvd drive and is common on some Philips machines. The only way to cure it is to replace the dvd drive unit itself, the one positive is that Philips used their standard IDE or SATA internal dvd drives, the same as in desk top computers. However a replacement drive would have to be comparable to the exisisting unit to avoid further complications. Please take note as a safety warning this is a technical solution involving the opening of the machine exposing potentially live electrical parts and should only be under taken by a trained technician.
Hope this info helps, James
Apr 22, 2010 | Philips DVP3040 DVD Player
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
May 31, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Disc door will not open
Open the unit and remove the DVD manually. The magnet that holds the DVD in place is stuck to the top cover.
Nov 29, 2007 | Lite On LVW-5005 DVD Recorder
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
Dvd recorder goodmans door sticking
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Sep 07, 2007 | Televison & Video
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Can not open the dvd tray
My DVD Drawer was stuck to.
Thanks; I hit both the top and bottom of the DVD player and lo and behold the drawer popped right open!
Jan 22, 2007 | Gateway AR-230 DVD Recorder
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Ekse
