Question about MSI K8MM-V Motherboard
Windows Installation gives blue screen errors.
I've bought a new mobo MSI k8mm-v. I connected my new SATA HDD on it. When I tried to Install Windows XP PRO it displays and blue screen error 0x00000024 its about having a anti-virus or defragmentation programs running. and also about installing controller drivers. I didn't find any other programs running. I also tried installing Raid drivers. But there's no fix there. I dont know whats wrong here. Pls. Help me guys!!! MSI K8MM-V Sempron 3100+ GeForce FX5500 512MB DDR 400 RAM 80GB SATA HDD
  • Anonymous Dec 26, 2007
    Hi I have MSI MS-7142 (K8MM-V) motherboard and its driving me nuts . It gives errors like IRQ NOT LESS THAN OR EQUAL, MACHINE EXCEPTION HANDLING, PAGE FAULT ERROR- all the bluescreen errors. I have replaced my RAM and downloaded new drivers and the errors have reduced there timely occurrence but arent totally solved.
    PLEASE HELP!
    Novelist:
    Champion:
  • 231 Answers
Hi, at the boot up go into your bios [ on MSI press the delte key continuosly] and turn OFF the onboard virus protection. This can block all O/S from loading as they need to write to the bios in the installation process. Ensure you turn it back on after installation, it is there to stop hackers getting into your bios and wrecking your system. Regards mistyman
Posted on Sep 04, 2007
What if bios doesnt have option to turn off onboard virus protection?
Posted on Jan 19, 2008
BIOS won't recognise SATA hdd.BIOS is Pheonix-Award BIOS v6. 00PG. Do you think I need to update the BIOS?
Hi, according to your mobo manual it supports SATA1/SATA2 hard drives so it's recommended to update BIOS, the latest I found it has release date 2006-06-29, you can find it in the folllowing link: Support For K8MM MSI Global
Nov 07, 2017 | MSI K8MM-V Motherboard
How can i install windows 7 on a new sata ******* a msi k8n neo4 motherboard with mainboard cd?
it has nothing to do with the motherboard make sure you format the hdd before you install the OS
Jan 31, 2012 | MSI Computers & Internet
I have MSI K8MM-V MOBO w/VT8237R Chipset. WIN XP 2 gig ram I have a WD7501AALS HDD to replace a WD1600JS-22N HDD Both are SATA drives Problem: The BIOS nor the POST will recognize the WD750. I have...
Hello, You need to right click on to my computer>Manage>choose disk management, you should format the new SATA HDD there.
If that will work for you that is good but if not, i thing you should updated the BIOS and you have to make sure that you get that update to MSI website. if you are not familiar w/ that asked some one who know how to flash BIOS. it is risky if you are not familiar doing BIOS update!!!
Mar 04, 2011 | MSI K8MM-V Motherboard
How to install windows xp in msi k8mm-v motherboard?
Hi dharmen_shah,
I see that you need to install Windows XP on you Dekstop with an MSI Motherboard k8mm-V.
I have another desktop using the same Motherboard, there are 3 options installing Windows XP on the machine.
  1. Using an IDE Optical Drive
  2. Using a SATA Optical Drive "not a common installation process on this motherboard" since you will need to install the SATA rivers first to be able to use your SATA ODD
  3. Using a USB Flash Drive
See steps below for each installation type.
*Using an IDE Optical Drive*
  • If you have your Windows XP CD insert it on the Disc Drive restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • Once in the Boot Menu screen select your Optical Drive, it may say dvd/cd or ODD, select this and press enter. Note: windows may restart during the installation if it says press any key to boot to cd do not press anything anymore leave it will do everything on it's own unless prompted for any user information like a computer name date and time.
  • You will see on the screen Boot to cd: then it will show "press any key to boot to cd" press Enter or any key this will boot from your cd Windows XP.
  • Then you will see inspecting your hardware for configuration, once it boots to your Windows XP cd you will see a blue screen Loading up drivers and stuff for the installation of Windows XP.
  • Next will be the installation of Windows XP itself, just follow the prompt it is very easy to follow and it will give you all the details and what buttons to click on.
  • Note: Select Quick Format (NTFS) this will be faster reformatting your Hard Drive before installation.
*Using SATA Optical Disc Drive*
  • You will need a 1.4 floppy disc to be able to do this.
  • If you have a 1.4 Floppy Drive you will also need to download the SATA driver from the MSI website.
  • Let us disregard this option since I believe you do no have a 1.4 Floppy Disc Drive and no one uses that or has a 1.4 Floppy Drive anymore on their machines.
*Using a USB Flash Drive*
  • To be able to use a USB Flash Drive for the installation of Windows XP your USB Flash Drive should at least be 1GB or 2GB, 1GB will be enough since windows XP only uses at least 7++gb of disc space for the installer size.
  • Using you USB Flash Drive you will need to copy the whole contents of your Windows XP Cd into your USB Flash Drive, don't worry this will be bootable just make sure that you copy everything from the disc into the USB Flash Drive.
  • Once you have copied Windows XP on your USB Flash Drive insert it to one of your USB ports on the machine then restart the computer.
  • Restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • This will be the same as using your Windows XP cd but instead you will need to select USB in the Boot Menu then press enter. on the installation steps it will be the same as installing using a disc.
  • Windows may restart during the installation and using a USB Flash Drive will be different at this point because it will boot directly to the USB, Once it restarts and may repeat the installation all over, to prevent this as soon as the system begins to restart from the installation go and keep on tapping "Delete" once it restarts this will bring you to the BIOS screen press F9 to set it to defaults then press F10 to save and exit this will restart again.
  • Once it restarts after setting the BIOS to defaults let the system boot on its own it will then show you a screen asking what windows to install the first thing highlighted will be the installation that was halted earlier just press enter then it will show you the windows installation page and will continue on it's own.
This is based on my own experience since I have an older Desktop that has the same Motherboard, I hope that I have given you all the options possible to installing your windows XP on your Motherboard k8mm-v.
Have a nice day,
mvincentc
Feb 02, 2011 | MSI K8MM-V Motherboard
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Problem with raid controller and lan how to fix? have disabled both other wise cannot boot up into windows blue screen.
if windows is blue screening, I would look into loose connections. Is the raid controller built into the mobo? Are you running your HDDs in a RAID? You know more about your computer than I do, I'm taking a shot in the dark here. boot off of the windows disk and select repair. if you can get that far, type in "help" or "/?" I can't remember exactly but it will display a list of commands. Choose diskchk. if windows determines there is a HDD problem, then you should try to re-install. If the new installation fails, then you have a bad HDD. If windows says there is nothing wrong, I would look into getting a new mobo.
Jan 17, 2010 | ASUS P4P800-E DELUXE ULTRA ATA133...
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Dec 14, 2009 | MSI K8MM-V Motherboard
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
SAMSUNG SATA DVDRW on MSI K8MM-V MB
try going into setup; choose boot options and place your HDD in first boot position. Also you may have to designate your new DVDRW as a slave if you have another CD/DVD in the system
Apr 16, 2009 | Computers & Internet
MSI K8MM-V Motherboard Logo
272 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
