Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5633WLMi Laptop
It doesn't recognise the power cable! The cable is switched on, plugged in, and the light on the adapter box (excuse the lack of technical vocabulary) is on. The amber battery light flashes for about 1 second in every 5 when plugged in, not at all when not. When the laptop was on, it wouldn't recognise the cable as being on. Even off, the light on the optical mouse comes on only when plugged into the mains. The power worked initially, fully charging the battery once, but stopped after playing a DVD (which shouldn't make any difference). It was less than a day old and now it has died. Help!
  • kikass Sep 04, 2007
    Nope, and following a phone call to the Acer technical advise centre, they have suggested either the power cable or the laptop need replacing (I suspect it will be the former). If you have any other suggestions in the meantime, please go ahead.
  • kikass Sep 09, 2007
    The problem was with the power cable. A replacement unit solved the problem.
    Scholar:
  • 181 Answers
Unplug everything that isn't necessary to run the laptop ie, external mouse, battery, etc. Then plug the ac adapter in, making sure the switch for 110/220 is appropriate for your region. Now, does the machine turn on? PLease respond with the answer, and we'll go from there. Good luck
Posted on Sep 04, 2007
  • jim walenciak
    jim walenciak Sep 08, 2007
    Well, sorry to hear that.
    If you have any way of checking the voltage of the tip of the ac adapter, just to make sure it's getting juice.
    Does it charge the battery? With the system off, will the battery charge (with the ac adapter plugged in of course)
    If so, it may just be a setting in power management, or a failed driver for power management.
    Good luck with the Acere service!
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
When I turn power on my acer aspire netbook the screen is black. The only light that lights up is the battery light. Do you know what is the problem and how can I fix it?
Have you tried turning it on using your adapter? If there is still no power light, try removing the power jack in the laptop and the power cable in the adapter and re-insert it both then plug it then test it again. If there is still no power light, try bending slowly the power jack cable in the laptop while inserted and slowly bend and move until you reach the power adapter. Observe the power light while bending the cable. If the light turns on while bending, the wire/s on the cable might be cut where you bend and see the power light turning on. If there's still no power light, your power adapter or the laptops power supply might be defective.
Sep 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Hi, my Acer Aspire 5633WLMi has started to turn itself off automatically after about an hours use (of just browsing on the internet) I've had the laptop for 2.5 years. I always have it plugged into the...
Hi, from what you are describing it seems like it is not power related, it could be overheating problem, the best thing you can do is to clean the airways in the bottom of your laptop especially under the fan with a compressed air can, you can find the air can in any electronics store just follow the instructions on the can and be carefull not to break the fan fins with lots of air presser, start slow and clean all air ways then give the computer a try... hope that helps
Jan 30, 2011 | Acer Aspire™ 5633WLMi PC Notebook
My acer aspire 5517 will not charge at all
Could be your power supply, it could be bad and is not charging. Check to see if the green light come on, on the adapter. Try testing this if you have another charger, if not, try taking your battery out, and only using the power supply adapter only to see if the computer turns on. If not, then your charger is 100% history and needs replacement. If it does, could be your battery going bad on you. There could also be another possibilty that your power jack is broken, damaged or loose. Check and inspect your power outlet, the only way to be sure about this is testing your adapter to another device if it works/chargge the other laptop.
Jan 26, 2011 | Acer Aspire 5633WLMi Notebook
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
When typing, I get numbers instead of letters
Press the Num Lock key. The Num Lock indicator light should go out.
Have a good weekend.
Dec 19, 2008 | Acer Aspire 5633WLMi Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
