Question about Vivitar ViviCam 3730 Digital Camera
Formatting SD card
I Have just purchased a new SD card but the camara comes uo with a card error and askes me to format the card again, I select menu and select format and the same erroe comes up. Is thai a problem with my card or camara
  • arturo silva
    arturo silva Mar 17, 2018
    thank you all, still issue persists, I am using a micro sd card in a sd adapter, could it be the adapter is faulty? not allowing the micro sd to be read?
    President:
  • 261 Answers
Hi check the SD in memory reader that connect to computer > format the memory if problem exist> check for viruses> if memory reader can read it take out battery of camera and clean up the slot of memory cardBy
Posted on Dec 17, 2011
    Genius:
  • 2,985 Answers
Possibly either- or Take it back to the shop and ask them to check by inserting another card or card into another camera Get which ever it is play up replaced
Posted on Sep 04, 2007
SOURCE:
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
Tip
MICRO SD CARD WILL NOT FORMAT
If you cannot format an SD card on your PC or external device, retry choosing the exFAT format from the drop down menu (File system box) on windows, then format your SD card using this choice, then format again using fat32 format, this just worked for me and saved my SD card from the bin
1. Double-click My Computer, or Computer (for Vista and Win7)
2. Right-click the drive letter associated with your memory device, then select Format.
3.Select File system format drop down menu to be exfat.
4. Select quick format.
5. Select start.
6. When formatted, repeat steps 3 to 6, but this time select Fat32.
What is exFAT format?
exFat is short for Extended File Allocation Table. exFAT is a file system designed and used by flash drives.
exFAT is not used and was not designed for formatting hard drives. It is only recommended in flash memory storage and other external devices only.
on Nov 02, 2017 | Miscellaneous
Trying to format microsd to my lg9oo and it wont work asks for a code or freezes up on me. what do i do?
Hey
These steps should do the tick!
1. From the home screen press Menu then select Settings.
2. Choose Memory manager and select External memory.
3. Press Format and enter the password, which is set to 0000 as default. Your memory card will be formatted and ready to use.
4. To view the new formatted folders on your GW300 press Menu and select My stuff. Choose My memory card.
Cheers
May 21, 2011 | Kingston MicroSDHC 4GB (4 Gigabyte) Card...
How do I format the sd card in the DMC_ZS7
Welcome to FixYa.
To format the SD card, select [Format] from the [Setup] menu
To bring up the Menu option, press the Menu/Set button. Then select [Setup] and then select [FORMAT]. Then choose Yes to format the card.
Please note:
This requires a sufficiently charged battery, or an AC adaptor (optional) and DC coupler (optional). When
formatting the built-in memory, remove the cards.
(Only inserted card will be formatted if present; built-in memory will be formatted if no card is inserted.)
• Always format cards with this camera.
• All picture data including protected pictures will be deleted.
• Do not turn off power or perform other operations during formatting.
Thanks for using FixYa.
Feb 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Hello sir my sanyo digital camara S4 not detect sd memory. when i put memory asking format if press ok nothing hapen then coming mesege no image what hapen?/ help me withou memory camera is ok
Formatting the memory card according to rhe camera's supported format should fix this. If after formatting and did not work, it means that the memory storage device is faulty. You have to replace your memory card with a new one to make take and save pictures again.
Jun 01, 2010 | Cameras
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Card error samsung s730
I own a Samsung S730, i downloaded all the drivers on Vista Home, I tried formatting the SD Card but it says CARD LOCKED, and it isnt. Any solutions
Oct 25, 2007 | Samsung Digimax S730 Digital Camera
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
SD Card Formatting
in windows XP, select My Computer icon, right-click the icon and select the SD card. Now right-click the mouse button and select ?Format? from the pop-up menu. The formatting will commence.
Oct 04, 2007 | Microsoft Windows XP Professional With...
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Vivitar ViviCam 3730 Digital Camera Logo
208 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
