Question about Canon EOS-20D Digital Camera
Canon 20 D does not work with card in
Error cf appears, read manual, followed steps to format card and error 99 appears. camera operates ok without card in.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Open memory card chamber to see if one or more pins at the bottom of the chamber are bent or broken off...careful straightening the pins because they can break off... should be done by an expert.
Posted on Sep 04, 2007
  • 3 Answers
It's possible for CF cards to get corrupted as well. Try another card. Nothing to lose right? Also, I'm part of this Canon camera group on MSN. This is one of the better ones. To help solve these kinds of problems and any other advice check with people who own the same camera as you. http://groups.msn.com/TheCanonDSLRPhotog...
For example, go to the Group Discussion board for most problem solving. It's a great group and guaranteed to help you with other photography issues and also become a better photographer.
Dave/Photobiff
www.photobiff.smugmug.com
Posted on Nov 22, 2007
  • 3 Answers
I had this problem today(error 99) I did all the solutions above and nothing work. So I removed the main battery pack,  I have the dual type and after min or so I reinstalled the battery pack and it works now.???
Maybe it will work for you too?
Posted on Oct 23, 2007
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
Canon error 99
.1. Turn off the camera.
camera body.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My canon eos rebel xti keeps showing error code 99
following:
steps:
camera body.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS-20D Digital Camera Logo
109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
