I have a 51" Panasonic Rear Projection HDTV,
  • Official Brand Answer
  • 350 Answers
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Posted on Oct 24, 2013
SOURCE:
asnowman
  • 788 Answers
SOURCE: The red power LED on my 4 yours old PT-47WX54J
If your Panasonic Television is blinking 3 times then you have a short on your power supply and the most likely suspect is your convergence IC’s.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts, and your will get a repair kit instead of just the IC's.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jan 31, 2010
Slinteriors
  • 8617 Answers
SOURCE: Panasonic HDTV Projection PT-47WX42F won't turn on
Your Set is going into shutdown mode due to the convergence section of your television. Thats what 3 blinks mean. It could be just the Convergence ICs and resistors or you may need a new Signal board TNP2AH035 Let Me know if you need further assistance with this problem.
Posted on Feb 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: power up
is it a constant blink, or does it blink a nummber of times in between payses? Let me know the number of blinks. Please respond to this same post so I have access to previously posted info.
Posted on Jul 01, 2008
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
Hello I have a Panasonic PT47WX53G and when I turn it on the red led (Power) comes on and then blinks 5 times, then it turns Off. After a few seconds the red led turns on again blinking 5 times. This cycle repeats until I unplug the TV.
Thank You Willie
Posted on Jun 01, 2010
Panasonic 51'' HDTV Model PT51HX42F - Turns off, light blinks 3 times, pauses, blinks 3 times again, etc.
the 3 blinks is caused by convergence failure indicating the Convergence ICs and resistors need replacement. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the ICs and resistors and also has the CD that shows how to do the repair.
Jul 28, 2012 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic pt-51hx42f replaced 2 convergence chips and 6 convergence resistors. still can move any of the convergence set-up arrows. was told it might be the pico fuses. But I cant locate them on the...
No thats not the Problem you have to know HOW TO ENTER SERVICE MENU Their is a Long Step in getting into the SM
if not done correctly you can really Mess this TV up! Once you Enter the service menu then you can go to convergence and adjust
to correct Pattern,Then you Must Exit correctly with the Save Mode to Save alinement or you will have to adjust all over again.
Sep 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic 56" HDTV Projection TV. Model PT-51HX42 TV power button flashes 3 times and then turns off
You have a defective temperature sensor
3 blinks flashes oncenevery 5 seconds
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from www.TvRepairKits.com. Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic PT-51HX41 51 inch
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Pioneer PT-51hx42f
hello. it sound like a power supply . problem to me.!!! check it.!!! "good luck"
Aug 02, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Ekse
