SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
SOURCE: cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
craig:)
SOURCE: Cassette Recorder play problem
Left(Playback) deck of cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and Fast Forward stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. I suspect the end of tape/tension sensor is the culprit but do not know where it is. Have not taken any steps except finding this site first off!
SOURCE: Canon GL1 Remove cassette error
I certainly don't intend to be rude or obnotious but your comments on this known prpblem are contraditory to say the least! :
"The problem that you are experiencing with your Canon GL1 camcorder is
a common complaint on this model camcorder. The “eject the tape error”
is the camcorders way of saying something is wrong and it needs to be
sent in for repair. It is not a defect with the camcorder, it is simply
the most common complaint when the mechanical assembly is not running
smoothly and perfectly." If something is wrong and it's a common problem then it must be defect?!?! Also your pricing for this "repair" is pretty close half of what a used GL goes for over here in Europe. I would definatly be looking for another quote and repair service other than yours!
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
