Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
Problem for Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg...
I ahve a schiller welch allen EKG machine, and now it only prints
By ap43 on Apr 05, 2009
I changed the type of electrode and this made it better for only 1 EKG. Why will the machine not print the entire EKG
Solution #1
posted on Aug 31, 2009
Not Rated)
watsmesa
Rank: Guru
Rating: 87%, 16 votes
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Comments:
Aug 31, 2009
- If it stops half way through the printing and shuts off, it is the battery. If only some leads print out and other are flat it is either bad/expired electrodes, one or more bad/intermittent lead wire or your lead wires are mislabeled or in the wrong spot. If it just fads the printing halfway through the print then you need a new paper cover. i can help more with this if you give me more feedback. info@mesasales.com
Was this helpful?
Yes
No
Popular Solutions for Schiller Welch Allyn Cardiovit
Questions and Unsolved Problems for Schiller Welch Allyn Cardiovit
Do you recommend Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine?
Answer
Answer
the printer stop when you request to print out and in auto mode print only seconds time
Answer
welch allyn schiller cardiovit at-2 type CH-6340 need information how to install the paper
Answer
hello there i have a problem with my 2001 audi a4 1.8t quattro ...my engine check light came on... (More)
Answer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Schiller Welch Allyn Cardiovit...:
Top EKG / ECG Machine Experts
Rank: Guru Guru
Solutions: 3887
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more EKG / ECG Machine Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
