Labels feed and print seems to be in white
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Is your ribbon install correctly?
Have you tried a calibration?
You may have to adjust the print head.
