Question about Nokia 6288 Cellular Phone
Help me retrieve my contacts
I have a Nokia 6288. It recently stopped working. It's just a black screen. I tested it by dialing my home number on it and the home phone rang. So it works, but i can't see a damn thing. I have a spare phone, but the problem is that all of my contacts are saved to the phone and not the sim. So I was hoping that maybe some wonderful person could patiently write down all of the areas on the phone i need to go into (eg: top left, midde, bottom right middle etc) to save them to sim card. Obviously this has to be spot on. Bit of a challenge really. I know it's in contacts and then names somewhere. If you could test in your phone and write in down for me than that would be awesome. Such a pain in the bum. thanx alot.
  • mikilo May 10, 2008
    screen is black but all things on phone still appear to be working e.g i can still ring and receive calls but cant see anything on screen
  • jerstar19 Dec 08, 2008
    My phone is a samsung z720. the screen black out as well, but i am still able to play music with it. But i didn't save my contacts to my SIM card, so now i have lost virtually all my fren's contacts. ><
    Problem Solver:
  • 18 Answers
Please connect u r phone to PC and launch nokia PC suite, backup u r phone contents or copy u r contacts to local disk . please rate this comment.
Posted on Sep 12, 2007
    New Friend:
My Nokia N85 has gotten wet and wont turn on. Unfortunantly all of my phone contacts are saved to my phone, so how do I get them back?
Posted on Dec 16, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
Try to conect your phone with the PC and throu the pc suite you can read your contacts
SOURCE:
I deleted dialed numbers on my Nokia N70 pls help to find them
its not possible to retrieved deleted dialed numbers from your phone because you phone does not have a recycle bin. A computer as recycle bin that's why deleted files are retrieved.
Contact your service provider, they should be able to give you a list of your dialed numbers. Usually, your service provider keeps a record of all your incoming and out going calls.
So try your service provider.
Good luck.
Oct 06, 2010 | Nokia N70 Cellular Phone
A VOICE RECORDING STATES THE TERM ''MAO1GK'' AND THAT THE NUMBER CAN NOT BE COMPLETED AS DIALED, I BELIEVE THAT MY DIAL UP NUMBER FOR MY VOICE MAIL WAS ACCIDEMTLY PARTIALLY ERASED
Contact AT&T Customer Service for your voicemail retrieval number. They can walk you thru resetting it in your phone. They are the only one who have this number to your voicemail.
Mar 05, 2010 | AT&T Nokia 6085 Pay-As-You-Go Cell Phone -...
Nokia 6288
try this and will solve the problem :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck .
rate if useful please !
Nov 10, 2008 | Nokia 6288 Cellular Phone
Nokia 6288 need puk code
hey the puk no. is sim specific and not phone specific..so you have 3 options:
firstly you can dial the landline number of customer care of your service provider(which every service provider has and you can get it anywhere where you get recharge vouchers)..and restyou know just ask
secondly take a friends phone with same service provider and dial the standard customer care no. rest you know
thirdly you can go to your service provider outlet shop..
Aug 29, 2008 | Nokia 6288 Cellular Phone
Nokia 6288
hey your service provider will have a 10digit customer care number also which you can dial from a landline phone..you can get this number from where you get recharge vouches..call them and they will give you youe puk number
else take phone of a friend with same service provider and call the customer care rest you know wat to do..
Listing contacts
to list a contact the easy way just type the number it and press options and it will display save go from there
if some one called and u missed it when the screen shows one missed call it should show the number if not it was private u can also go in to call log and go to dialled calls.recived calls.and missed calls and will show u the numbers
Jun 28, 2008 | Nokia 6288 Cellular Phone
Unlocking code for Nokia 6288
just give me your mobile IMEI no by typing *#06# at the screen ........and i will definitely will send you mobile unlock code.
Dec 24, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 - received an SMS, phone screen went blank
This issue can also be resolved simply by removing the batteries first, then remove your SD memory card, clean the SD card up with an eraser on it's gold/copper contacts, clean it and replace battery on the phone and turn it on. It would turn on, and then you can put the memory card back in. It is a common 6288 bug.
Unless this suggestion works, then you can follow the reset codes given by gizmo above...
Nov 09, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 Cellular Phone Logo
949 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
