Question about Whirlpool Duet GHW9150P Front Load Washer
F-H Error I accidentally ran the washer when the water was turned off. Now I am getting the FH error, and my clothes are trapped inside! After reading my troubleshooting guide, I pressed pause/cancel twice, unplugged the machine, turned it back, reselected the cycle, and pressed Hold to Start. The machine just makes a noise that sounds like it is draining, but there is no water inside. The clothes are still dry, and they are trapped inside.
We just had the same problem. We disconnected the water hoses in the back (after turning the water off) and cleaned the sieve. Usually it works again after that. Unfortunately after a couple of washes the problem reoccurs...
Posted on Sep 04, 2007
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Maytag front load FH error msg
May be a water pressure sensor problem.
This tells it when the tub is full.
start with this video
https://www.youtube.com/watch?v=2pIVkAxWSXg
Nov 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
F h flases
First try turning off the machine for 30 minutes. Still FH? Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Mar 31, 2013 | Kenmore Elite 45986 Front Load Washer
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
Timer display blinks fh on maytag epic front loader
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
HE3t has an FH error code checked the following and are OK. pressure switch, flow meter, and inlet valves water flows in without restriction. What else could it be? Craig
Thank you for contacting fixya.com.
FH error code means low water inflow. In this error washer is not filling when the fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the water shut off valves clockwise to stop the water flow to the washer through the supply hoses. Pull the washer away from the wall enough that you can access the hose connections at the back of the washer.
Set a bucket under the area of the hose connections. Unscrew the hose connections from the back of the washer. If necessary, use a pair of slip joint pliers to help start the connections turning until you can turn them by hand. Set the ends of the hoses inside the bucket.Inspect the screens on the inlet ports on the back of the washer where the hoses connect. Sediment and other debris can block these screens, causing fill problems. Clean the screen with an old toothbrush.
Thread the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off water supply to the washer which causes the FH error code. Once you connect the hoses, turn the water supply valves counter-clockwise to supply water to the washer. Move the bucket away from the washer and push the washer back into its working position.Plug the power cord back into the outlet and start the wash cycle again. If the FH error code comes up again, call a service repairman. If the hoses have no kinks and the inlet screens are clean, there is a problem with either the pressure switch or the flow meter.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Nov 28, 2010 | Kenmore Washing Machines
FH error because I had the water turned off
The FH code means that the unit isn't detecting water at the flow meter. The flow meter sits just in front of the inlet valve and is attached via a hose, and off to the left the CCU. Check the wiring from the flow meter to the control unit and make sure all connections are tight. Also, press and hold the "end of cycle" button for a minimum of three seconds. Hope this helped and best wishes.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 Front load..error code F H
**Before you begin make sure to turn off either the hot and cold water valves.**
The resolution is to remove the hot and cold water hoses connected to the back of the washer and remove and clean the microfine filters located inside washer's intake valves.
*The purpose of the filter is to capture all of the mineral deposits from harsh or rusted water particles.*
Basically, unscrew the hoses (connected directly to the back of the washer)
Carefully, remove the filters (they are very sensitive and could puncture easliy)
Clean them off with an old tooth brush in soapy water.
Finally, replace the filter(s), hoses and finally turn on the hot and cold water valves and best of all you will save yourself about $125!
Cheers
Aug 18, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag epic front loader
Suggestion: Check the wall inlet to see if water comes freely; then check if the inlet valves behind your machine to see they are not clogged. Best that u open the valve full before you begin your wash. The water coming 3 inches/door is normal. Dont try opening the door until after you hear a click or aft 2 or three minutes aft wash cycle completes.
Sep 11, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
117 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
