Euro-Pro Shark 18Volt Pet Perfect II Cordless Handheld Vacuum Cleaner Logo
Anonymous Posted on Aug 11, 2013
NEED CHARGER --> KA12D075015023U - Euro-Pro Shark 18Volt Pet Perfect II Cordless Handheld Vacuum Cleaner
1 Related Answer
Anonymous
  • Posted on Feb 12, 2011
SOURCE: I NEED A CHARGER FOR
i need to buy a new chager model v1725qc
1helpful
I need a charger for my Dust Buster.
You don't need an actual charger that says Dust Buster on it. You can use any charger of the same voltage from some other gadget. Most are 9 volt. Not all, but many are. Just look on the dust buster tag & see what it requires. Some stores like Radio Shack even sell the charger with several adapters..One sure to fit your Dust Buster. Good Luck. This is a pic of one that is $13 at Walmart.
Apr 05, 2018 • Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
The red light keeps blinking while I have the charger plugged in, is this normal?
Hi! If the light on the charger is blinking this can mean an issue with your charger adaptor. Check that the charger is still warm. If so, unplug the charger for a few minutes and plug it back in. If the light is still blinking your charger adaptor may need to be replaced. Hope this helps!
1helpful
I need to purchase a shark model v1725u charger charger # ka12d075015023u can you help me I misplaced mine
Hi Carol,
Try this site: http://www.emtcompany.com/ka12d075015023u-ac-power-supply-charger-adapter/101318815.html
Handie Andie
Jun 05, 2011 • Vacuums
Can I get a charger for a powerbase screwdriver? I've lost mine. Jacqui
Find out what voltage is required for the charger and any universal charger with a compatible connector will work. Batteries are rated at 1.2 volts, so if the screwdriver has 3 batteries you need a charger that delivers about 4 volts. A good hardware store should be able to supply you with a suitable charger.
Jan 17, 2011 • Vacuums
4helpful
I need to purchase a new adapter for a Shark Cordless Sweeper model #V1700Z, adapter #KA12D075015023U. Can anyone shed light on this problem. Otherwise I have to through away the sweeper.
what you need is a 7.5 volt DC 150mA charger. If you check on some sites like ebay you may locate one. Another option is you may be able to go to an electronic repair shop and they might make one up for you. You nedd to bring them the sweeper so they know what connector needs to on it. A 7.5 volt is not expensive or uncomon and barrel plugs are cheap also.
Sep 27, 2009 • Vacuums
Lights on charger do not light and therfore do not charge roomba.
If the charger doesn't light up, it's broken.
Call customer support at 1-877-855-8593. Be sure to have the Roomba and charger with you when you call-- you'll need them.
2helpful
NEED CHARGER MOD:HHD20-200
I have same problem. Please post it if you find source of battery charger HHD-20-200.
Apr 18, 2009 • Vacuums
2helpful
Adapter
Go to www.sharkcompany.com but it costs $12.00
My dog chewed mine up!
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
