Question about SAMTRON 78DF 17" CRT Monitor
I have the SAMTRON 56 V 14" COLOUR MONITOR .
HELLO, the monitor i have is SAMTRON 56V 14" COLOUR MONITOR .WHEN EVER I STARTS MY PC THE control Locked appears with locked signal i could not exit from the problem and moreover the screen size and controls like brightness/contrast/ and other controls cannot be adjusted . will any one facing the same problem? is so what is the solution to come out of the problem? bye radha .
  • Anonymous Sep 12, 2008
    I am also facing same problem ...please let me know if u have any solution for this
  • darshak37 Mar 29, 2009
    my problem is to remove the nagging screen setting menu which keeps
    popping up in the middle of the screen. even after pressing the exit
    button
    on the monitor it is not going
Change the eprom (A41dDC) after connect pc then switch on monitor
[email protected]
Posted on Nov 22, 2008
    Problem Solver:
  • 13 Answers
It could just be a problem with the montior as it is a rather old one you could try going into display settings and changing the screen size and brightness/contrast and other controlls. or you could always just buy a new montior can get lcds these days for £50.
Posted on Sep 08, 2007
SOURCE:
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Jul 02, 2009 | SAMTRON 78DF 17" CRT Monitor
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor problem
i think the problem is in your monitor and it is not manuall. any part of your monitor might have been damaged ,so get it checked by an hardware expert
Feb 24, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
Open Questions:
SAMTRON 78DF 17" CRT Monitor Logo
466 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
