Mostly black lcd screen (can see slight picture/image) when turned on, flash works, pictures are taken and stored, but cannot view in viewing picture mode. No other screen shows. Memory chip stores all pics taken, and can be shown on computer or such.
but..i can't seen a damn thing!!!!1
i can't see the display things..i can't see my pictures, or can tell which picture/video im even deleting because my screen is blacked out.
can i fix this on my own??????-   Guest
Feb 16, 2009
-   Very black screen when a pic is taken! Can see an image through the screen ,but BARELY! Looks like black lines when you are looking at an image!-   wendyhartzel
Jan 25, 2009
-   My screen is all black except a stip horizontly in the middle that shows the pics, I havent tried to download the pics on the computer yet though-   datonee
Dec 24, 2008
-   I can barely see what is on the LCD screen but it is working. . .
-   tigerina
Nov 07, 2008
-   The backlight seems to be burned out.-   cmeyer312
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
This may sound crazy but it actually just worked for me!!! I left my camera in my lunch cooler one day and when i took it out it in the hot sunlight it fogged up and the screen was VERY dark. I did not mess with if for a few days hoping it would dry out. That did not work then i had the crazy idea of blowing it with a hair dryer . . . .it ACTUALLY worked! I couldnt believe it, i was about to go out and just buy a new camera and then that worked YAHHHH! Hope this helps someone else!
Was this helpful?
Yes
No
Solution #3
posted on Oct 31, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if you can, I would press MENU Then click Set Up then click monitor settings, select brightness, and select high light if that doesn't work, im terribly sorry.
my clicksmart 420 is very old about 10 yrs i love this camera but all i get on the screen is PC ...
(More)
my clicksmart 420 is very old about 10 yrs i love this camera but all i get on the screen is PC what can i do to fix it
My Logitech ClickSmart is interfaced to a pc. Today on the pc the shot has horizontal lines going...
(More)
My Logitech ClickSmart is interfaced to a pc. Today on the pc the shot has horizontal lines going accross the image, which flicker and eventual there is almost no resolution. Sort of like when the video stabilizer went on old color TVs.
i have a logitech clicksmart 420 and didnt use it for a while but now i want to use it and i now...
(More)
i have a logitech clicksmart 420 and didnt use it for a while but now i want to use it and i now have a windows vista computer i lost my downloading CD for instalation so what can i do now ? please help
have pictures on logitech clicksmart 420, have camera plugged into my computer, pictures do not...
(More)
have pictures on logitech clicksmart 420, have camera plugged into my computer, pictures do not appear on computer, what am i doing wrong?
Fuji S7000 has slight purple edge in one corner of LCD, otherwise is black. Camera seems fine otherwise, but cannot see what I"m planning to shoot either on LCD or in viewfinder. Camera lights up fine, setup and menu screens are fine, just no view of potential shots. Weird...
Comment by Guest, posted on Jan 16, 2008
Same problem - I've tried to reset the camera and it didn't work. Also I have turned up the lcd screen on the brightest it will go and it did not work. I have a call into a repair store....
Comment by Guest, posted on Dec 25, 2007
When I take photos using the flash (some not all) turn out black for a couple of pics and then the next few will be normal again. I have tried different settings, Auto, Manual nothing seems to work and you never know when the pics are going to come out black. Does anyone know what the problem might be.
A few months ago the on board flash stoped working so Im using a mount flash, I dont know if that has anything to do with this.
I have the same problem with a camera I recently purchased (2nd hand for my daughter). The screen is so dark it's impossible to make out any image, but the setup screens are fine. If it's the back light can these be readily purchased and fitted ?
My Nikon D50 pics are dark only when my mounted flash is on(952AF/NIK). The flash goes off, but the pics are realy dark. When I use the built in flash this does not happen. I've used my mounted flash plenty of times already & this never happend. any suggestions?
Our camera is starting do do this now too. You can make out a very faint image, if there's enough light. It's like shooting blind. You hope you get the subject in the shot. Once the flash goes off, you can see the image you took for a few seconds but not while setting it up. Someone mentioned the backlight and circuitboard... how are these fixed? Are they replaceable at home or is this a repair situation? And would any repair shop do or do we have to send back to Fuji?
