Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Games destroy tvs?
I've only had this tv for a short time, about 2 years, and, at first, my parents wouldn't let me play games on the tv. Eventually, they let me, and a short time after I started playing games on it, the tv wouldn't turn on. The red standby light would blink, but nothing would happen. So we took the tv to a television repair place, and they replaced the circuit board, and it worked fine again. Now, a second time, only about 1 month after we repaired it, the same problem occurs again. My parents are convinced that my video game console broke it somehow. Is this possible? How is this so?
  • Michael Cho Sep 09, 2007
    Thanks for the help. I also have another question:
    Would this be the same situation with an LCD HDTV, as opposed to a tube tv? Because I know LCDs originated as computer monitors, and therefore may be more durable against a high resolution signal.
Change my parental controls on samsung tab A sm-t550 to download more apps
You need the parent that put the controls on to change it.
Change the Parental Controls for the Play Store Using an Android ...
www.tomsguide.com/.../change-parental-controls-play-store-android-smartphone.htmlMar 16, 2017 - While using your Android smartphone, there might be times when you want to restrict access to the Play Store in order to keep your kids or any unauthorized person from buying or downloading any unwanted/adult app online. ... By setting the parental control on Google Play Store on your ...
Set up parental controls on Google Play - Google Play Help
https://support.google.com/googleplay/answer/1075738?hl=enNote: Parental controls don't prevent seeing restricted content as a search result or through a direct link. How parental controls work. The way parental controls work varies across Apps & Games, Music, Movies, TV, and Books. Read the sections below to learn more. Note: Parental controls for each type of content aren't ...
Mar 26, 2018 | Tablets & eReaders
Why won't anything work?
Some game systems have power fail protection. My WII needs to have both ends of the power cord unplugged for like 2 min to reset the power supply. Maybe this is your problem>
May 17, 2013 | Microsoft Xbox 360 Console
Hook up a n64 to a rca xl100 tv
Precautions Concerning TV Screen Damage (Image Retention)
Some televisions can be damaged when a stationary image is maintained on the screen for long periods of time, as this could potentially "burn" the stationary image into the screen. This image retention can result from a variety of sources, including test patterns, VCR on-screen programming screens, or picture-in-picture boxes. Playing video games with stationary images or patterns, or leaving video games on hold or pause, may also lead to this type of damage.
Before using your Nintendo system with any TV, especially front and rear projection type TVs, be sure to review all documentation included with your TV to find out whether video games can be played on the TV without damaging it.
When taking a short break, place the game on pause and turn the TV off until you are ready to play again.
If you are not sure about your TV, contact the manufacturer of the TV for more information.
Neither Nintendo nor any of Nintendo's licensees will be liable for any damage to your TV.
Projection TVs (front and rear):
Due to their design, front and rear projection TVs can be more susceptible to image retention. Remember to be sure to review all documentation included with your TV to find out whether video games can be played on your TV without damaging it.
High-Definition TV's (HDTV):
Projection style HDTVs display the image in much the same manner as other type projection TVs and as such, the same possibility of image retention exists. HDTV's that use a tube screen should be no more susceptible to image retention than standard TVs that use a tube screen. For either type of HDTV, follow the precautions on this page.
Plasma TVs or LCD Screens:
We have no information on Plasma TVs or LCD type TVs. Since image retention is a variable of the TV, please check your TV manual or contact the manufacturer directly before connecting any video game system to your television.
Nintendo repAir center
May 13, 2012 | Nintendo 64 Console
Do n64 av to hdmi cable exist
Dec 30, 2011 | Nintendo 64 Console
My snes will not work with my Dynex tv. I have all the cables and plugged them into the correct ports. Anyone have any thoughts?
Oct 18, 2011 | Nintendo Super NES Console
We've had a 42" LCD/HD
Tries tv unplug,replug it back like about an hour later.Most of the times tv will resetting itself back to the factory setting and will work again.If still have the same problems,tries pushes the power button on/off a couple times for trying to fire up the tv Tuner signal board,these off/on tries work with many LCD/Plasma HD tvs.But this kind of problems,eventually u have to change the tv Tuner signal board sooner or later.Because the tv Tuner signal board it is dying,and this solution is just a temp fixed for the delaying it for awhile.
May 25, 2011 | Televison & Video
Ive managed to connect my snes & my n64 to my new tv using the multi out cable but the picture is very dark & hardly visible, sound is good though.
Feb 15, 2011 | Nintendo Super NES Console
I have purchased an element flat screen....problem is that there are no codes for an element...plz help cuz i love the remote!
Try finding out what parent company makes the Element. It should say it on the back of the manual. 1. Google the parent company 2. Find out what other TV they make. 3. Try the codes from the other TV the parent company makes. Good Luck. FYI, The parent company 90% of the time use the same parts in all their TVs. So the codes are mostly the same.
Jan 24, 2009 | Televison & Video
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
LCD Durability?
The answer is Yes definately to you question. The reason being is easy. The image cannot be burnt into the phospor of the LCD SET because it is "Liquid crystal Display which is backlit and is very durable. Just look at all the laptops out there and how reliable they are. All LCD. Also lighter, but dimmer then Plasma. I hope this helps you and your parents for some clairification. Good luck gaming. And have fun... Jay the GURU
Sep 11, 2007 | Sanyo DP32746 32 in. LCD Television
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
