Question about Panasonic ToughBook 52 Notebook
Toshiba laptop Tecra 8000
I was on the internet and the computer went down to prevent damage to my computer. the following message came up Stop:0x0000007B. i first put the system back on the computer like it directed me to with no results. it is telling me that I don't have a hard drive on my computer. that is not so. I was working fine. pls help.
  • 1 more comment
  • jojo_beans1 Mar 22, 2008
    every time i turn on my laptop, it does not go through the start menus ihave tried. it is not booting up. it just keeps restart the start up menus over and over agian...........? please help
  • guajo3 Nov 12, 2008
    mi camara
  • collins204 Jan 06, 2009
    Do you recommend a specific hard drive to replace it with
  • 184 Answers
My understanding is that the error occurred when the OS is switching from real mode to protected mode. The OS is loading the drivers necessary to access the boot drive in protected mode. Today’s PCs or laptops access the drive controller via PCI bridge chips. If the correct PCI driver or other disk device drivers are not in the image, the system will blue-screen. Hence the Stop:0x0000007B error code.
These are some of the following devices that might have failed.
  • PCI standard host CPU bridge
  • PCI standard ISA bridge
  • Plug and Play Software Device Enumerator
  • Primary IDE Channel
  • Secondary IDE Channel
  • Disk Drive
  • Standard Dual Channel PCI IDE Controller
  • Standard IDE/ESDI Hard Disk Controller
A specific OEM BUS master IDE, SATA controller, Boot Virus and corrupted Registry component might also be the culprit.
Simple fix is to boot your laptop to "Last Known Good Configuration". If it still gives you this option.
If it doesn't you will need Genuine copy of Windows CD and run a recovery program. Using a chkdsk command.
To do this you will need administrative privileges on your Laptop and insert the Windows CD as if you are going to install a new copy, let the program run its test and wait till it gives the option to repair, then press the F2 key to launch the recovery program follow the instructions to access your C:\ drive then type in chkdsk /r. Your system will now search for missing and corrupted system files and registries, after that it will restore those entries. It will take a while so be patient after that it's gonna tell you it is done. Remove the Windows CD in your CD-Rom and restart your laptop.
If it fails again you may need to reinstall your Windows backup your files and begin reinstalling Windows.
How to backup?
Remove your Hard Drive from the faulty laptop and connect via USB cable to a working PC or Laptop.
You can buy Laptop HDD casings for less than $30 on a computer store. It doesn't require you to install drivers for it cause it works like a USB flash Disk.
If you can access your files back it up.
If you can't have your Hard Drive replaced it's broken.
If you are able to backup your files successfully and still unable to reinstall windows. Take your Laptop to a tech and have it serviced one or several components of your laptop might be failing.
Posted on Jan 22, 2009
  • Panasonic Master
  • 12,061 Answers
What the computer is trying to tell you is that the hard drive has gone faulty somehow... hard Drives can and do spontaneously fail all the time.. It probably shut down because it detected a serious fault with the hard drive. I think that at least you are going to have to try a new hard drive to see...
Posted on Sep 04, 2007
SOURCE:
Password on motheboard toshiba tecra a8-ez trobleshoot
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Feb 01, 2013 | Toshiba TECRA 8000 (P000257480)...
How to access the bios of a toshiba tecra 8000
Turn the computer off completely, and then turn it back on.
Press and hold the "Esc" key on the keyboard immediately after turning the computer on. After a moment, the computer will prompt you to press the "F1" key to enter the motherboard BIOS configuration utility.
Press the "F1" key when you see the prompt. The BIOS configuration utility will load.
Jul 21, 2011 | Toshiba Tecra 8000 Notebook
The power was turned off. Now get a warning: system resume failure. What to do to restart?
When you get the resume failure message, push and hold the power button until the unit turns itself off (usually around 5 seconds). Once it is turned off, press the power button again to turn it on and it should boot right into windows for you.
Jun 03, 2009 | Toshiba Tecra 8000 Notebook
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
When using ac adapter to my Tecra 8000 the power light is yellow
Try a new battery and if the new battery wont charge then its either going to be a bad ac adaptor or a bad motherboad. If the new battery charges then you'll know that the old battery went bad.
Mar 29, 2009 | Toshiba Tecra 8000 Notebook
Toshiba tecra 8000 EC/KBC update
go to system setting by pressing F2 when you see the toshiba or bios logo
disable the system setting auto update.
Mar 16, 2009 | Toshiba Tecra 8000 Notebook
Toshiba tecra m5(network controller)
Hi, if you can connect to the internet via ethernet cable or on a different computer you can down load the driver from several different locations, or just go to Toshiba's web site. This is a alternative http://driverscollection.com/?H=Tecra%20M5&By=Toshiba
Nov 29, 2008 | Toshiba Tecra 8000 Notebook
Wirerless
toshiba tecra 8000 does not have built in wireless, you need to install an external wireless adapter (usb or pcmcia), and use the software provided with the wireless adapter to configure it
Jul 06, 2008 | Toshiba Tecra 8000 Notebook
Upgrading my tecra 8000 mother board
You don't have to change or replace your motherboard ..
just go to toshiba website........select your model by its serial No. and download the all available Drivers like Sound, Video, bios, management etc.....
install all these Drivers on your Laptop......... your motherboard will be up-to-date.
Mar 19, 2008 | Toshiba Tecra 8000 Notebook
Panasonic ToughBook 52 Notebook Logo
304 people viewed this question
Top Panasonic Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
