Broken wires at the ice maker temperature sensor can cause that problem. See my detailed posts under model RF265AABP for more diagnostic info and my solution to the problem.
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
1.Turn the blower fan OFF.
2.Press and hold the recirculation control switch and the rear window defogger switch down.
3.Turn the ignition switch ON (ll).
4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
- If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
- If the system is ok, the recirculation indicator stays off.
DTC TROUBLESHOOTING INDEX
DTC (Recirculation indication blinks) Detection Item Page
7An open in the air mix control motor circuit.21 - 16
8A short in the air mix control motor circuit.21 - 16
9A problem in the air mix control linkage, door, or motor.21 - 17
10An open or short in the mode control motor circuit.21 - 18
11A problem in the mode control linkage, doors, or motor.21 -19
12A problem in the blower motor circuit.21 - 20
13A problem in the EEPROM in the heater control panel;
(THE CONTROL PANEL MUST BE REPLACED).21 - 38
14An open in the evaporator temperature sensor circuit.21 - 23
15A short in the evaporator temperature sensor circuit.21 - 24
- In case of multiple problems, the recirculation indicator will indicate only the DTC with the least number of blinks.
- In case of an intermittent failure, the heater control panel will store the DTC until the ignition is turned off.
Hello. Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself. 1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel. 2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession. 3 Wait for the dishwasher to run a short diagnostic test. 4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Locate the lock button on the wall control. Press and hold this for 3 seconds. The blinking of the light should stop and your remotes will once again work.
Stuck remote control button. Check all remotes. check LED on receiver.
Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
