SOURCE: i need wiring diagram for hp computer motherboard.
ya u cand find that kind of features in the www.softpedia.com
SOURCE: I have a ASE380-UD440A PC. I need Pwr Supply wiring diagram.
It should follow the standard AT or ATX convention try this site
http://pinouts.ru/Power/
click on power supply connectors
SOURCE: hp pavilion 764c wire diagrams
Take a picture of the inside of your computer and put it up on the website with the wire connectors that need to be connected. The connecting wires should be in four groups. 1. The power supply connectors. These connectors will supply power to to all the power using components not supplied power by the motherboard itself. 2 The connections to the other components in your system like the dvd/cd player and the harddrive and floppy drive.3. The motherboard connections for the case. The power switch connector andreset switchconnector. The power led and theharddrive activity light.The USB connector and the audio connector.The fan connections like the cpu fan and other fan only connectors found on the motherboard.The external fans ( Fans that need to be connected to the power supply).Most of these connections are labeled on the motherboard. The case connectors also should be labeled for the correct connection. The best way to find the answers to this hook-up, may be to call HP pavilion with your computer make and model number,motherboard model number including revisions number. Computer made by big manufacturers tend to have may revisions and the only way to make sure your are getting a correct hook-up to the motherboard is call them for assistance.Especially if the motherboard and case labels are not present or so small that they cannot be read.Hope this helps you with your problem.
SOURCE: I need a wiring diagram for an HP Pavillion x1914
try this site mate :
http://search.hp.com/gwukeng/query.html?lang=en&qp=&h_audience=&qt=+wiring+diagram+for+an+HP+Pavillion+x1914+power+supply&la=en&hps=&charset=UTF-8&cc=uk&submit.x=6&submit.y=5&hpo=&hpn=
SOURCE: I need a wiring diagram for a hp pavillion 8660c
Can find what you need here:
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
Enjoy !
