Question about Sony KV-32S26 32" TV
COLOR PROBLEM JUST BOUGHT A USED SONY KV36XBR200 TV 2 MONTHS AGO.WORKED FINE FOR THE FIRST 2 MONTHS,NOW THE COLOR IS STARTING TO ACT UP.THE SCREEN TURNS MOSTLY RED COLOR, UNTIL I TURN THE CHANNEL.SOMETIMES THAT FIXES THE PROBLEM,MOST OF THE TIME I HAVE TO TURN OFF THE TV.WHAT CAUSES THIS PROBLEM? HAS ANYONE ELSE EXPERIENCED THIS PROBLEM?PLEASE HELP.
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Tv works then whirring noise like a motor stops and starts again
Bad Color Wheel Call Encompass for Part 1-800-638-3328 DO NOT KEEP playing TV untill this is Fixed other wise you can cause Alot of Damage to Set.
Sep 26, 2009 | Thomson 35776650 Bulb for 44DLP540 Rear...
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
9 red blinks
Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
Thanks
Tim
Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
Snow
There is a fault in the main processor that is causing noise. The set will have to be serviced. The tech will probably try the main video processing board to start.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Color bands at the top of the screen - Sony KDF-50E2000
I have the same TV with the same problems. Sony has issued a recall for these tvs. Contact sony and will fix it for free or give you a discount on another tv.
Apr 02, 2008 | Sony KDF-50E2000 50" HDTV
Can't get Video onto Television..Can get Audio.
Thanks for getting back five months later. I ended up buying a new Monster cable that worked just fine for like $40.
Dec 31, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Problem with display
Hello
If you only bought it 2 months ago it will be under warranty
You should send it back to be serviced as it sounds like a faulty LCD and it will need to be replaced
Dec 25, 2007 | Sony Ericsson W850i Cellular Phone
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Sony KV-32S26 32" TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
