Question about Kenwood KDC-519 CD Player
No response from the KDC-519
My radio still plays but I cannot adjust the volume, change the station, eject the cd, turn the power on or off, tilt the faceplate. Basically all the functionality is gone. The lights on it still come on but the lights around the am/fm all flicker. Any suggestions would be greatly appreciated!
I once had the same problem and took it in to have it looked at! The guy simply pushed in the small black button to the left of the ATT button and it reset!
Hope that helps!
Posted on Nov 21, 2007
SOURCE:
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Kdc-hd54u troubleshooting
unplug the battery see if that helps.
Mar 24, 2014 | Kenwood Car Audio & Video
Radio in 2003 jeep grand cherokee does not play cd's. it plays the radio stations, volume works, but it does not eject the cd or even recognize it .
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
Apr 10, 2012 | 2003 Jeep Grand Cherokee
2008 Nissan Altima radio (AM/FM/CD) does not respond to buttons except on/off volume. It was playing an FM station (cant't tune/scan) and now plays a CD that won't eject.
2008 Altima radio-the sound just quit working. Everything else seems to be OK. I can change the radio stations, but no sound. Is there a fuse that could be bad?
Nov 24, 2009 | 2008 Nissan Altima
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
KDC-519 HAS CD STUCK IN IT. RADIO PLAYS, BUT CD WILL NOT [email protected]
can you try to see the front panel of your CD player and find a very tiny hole there. you insert a small pin there about 2inches lengght at least and push it inside. if the tray is in the home position then you must be able to eject the tray manually but if it is stuck in the play position then the cd mechanism has to be dismantled
May 04, 2008 | Audio Players & Recorders
No sound thru cd player
are you using any separate amp?- if you are the blue wire on the back of the radio is probably turning off when you use a cd(the blue wire is for a power antenna, the blue with a white stripe is for an amp)
Feb 29, 2008 | Kenwood KDC-519 CD Player
Will not play
on the front panel, look for a tiny pinhole and insert a pin while powered up to reset
May 27, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-519 CD Player Logo
125 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
