Need Help Hello, I'm having trouble repairing a kenwood DTS Amp model: KRF-7775D. I have the service manual but still could not find any faulty components. Problem with this is that it works on it's own, seems it has a mind of it's own, so I seviced and replaced the memory backup caps near the main u-com and it fixed the "Mind" problem. Now it's doing exactly what I want it except no Audio output. checked everything, output stage, protection, muting etc. no luck. But if I remove the DSP assy ( which has the DAC's, sub u-com and the DSP chip) I can get audio from the dvd 6 channel direct input. sounds great. but if I insert the card the damn thing goes mute. so I checked the card ( voltages and the resets) found that the DSP power (3.3V) is missing. the funny thing is this voltage is present at power on and dies when the protection relay switches on and mute deactivates. The DSP is powered down and is not activated in any sound modes or input modes, so my guess is with the DSP power down the DAC's are not workin, and with the card removed the u-com bypasses this stage. I replaced the sub u-com chip but nothing happened. further checking revealed that after the sub u-com recieves the master reset from the main u-com, it powers down the 3.3V AVR. So after few seconds the after power on the 3.3V dies. I donno why, cud not think of anything, but I did find the master clk from main u-com to the sub u-com is at 3 volts. But to my knowledge it should be 3.3V. Cause it the clk goes via level shifter 5V-3.3V IC. so the input being at 5V with no data or clk output is 3V. All the gates of this IC show's 3.3V at high level. So may be this is a problem but the funny thing is I can see the clk from this out put, when change the sound modes which indicates the sub u- com is RX'ing it's data. so wht gives, why no sound. Pls can any one give me a hint on this issue. Rifaa
  • Rifaa-ath Razei
    Rifaa-ath Razei Sep 06, 2007
    Hey Thanks replying. Do u mind if I ask u who u r? and also u'r experience in this field. I just like know who I'm talking to.
    Any way I tried some more tonight, replace the level shifter ( the buffer only ) with a CMOS schmitt and the still the same 3V out put but now the clk is more clean, I mean strong, but still nothing the DSP is still powering down, so I checked the MDT port, which is the Master data to the sub u-com. And guess what no data what so ever, I mean the port doesnt even open at power on, (I use a little trick in measuring the ouput of digital gates, the complimentry otputs and it's undefined state at power on, I hope understand)what I do is I measure the continuity at the ouput with my DMM at diode check, this way I can here beep inturrupts when the gate is switching either at reset, power on or signal, always had worked this way. :)
    So at power on I can get beep inturrupts at clk, Master rst, sub rst, sub master request and sub slave request but nothing at the MDT ( Data output) all these pins is at the master u-com and goes to the sub u-com (which controls the full DSP functionality of the whole amp). So know I'm done, I can't go no further, My guess is the level shifter is working (probably) can't be sure without a scope. I can get the level shifter from china any time cause i got the sub u-com too. hehe.
    But the problem is I'm not sure what the problem is, the main u-com or the software itself or is it initializing fault becuase the backup caps were replaced or damaged, I dunno. Any one can suggest anything, all I need is seggestion, I can do anything almost if it doeas not involve a scope, cause it is way out of my budget. other than tht I can tackle any problem with the proper resources. Guys please help.
    thanks
    Rifaa
  • Rifaa-ath Razei
    Rifaa-ath Razei Nov 11, 2008
    Well after a long struggle, the problem was the golden capacitor. He hehehehe
    Problem solved
    Novelist:
    Scholar:
  • 114 Answers
I think you've answered your own question, circuit power is not going from one side of the DSP chip to the other and that suggests that the DSP's core is at-least partly DOA. You are indeed correct that functional power should be at 3.3V and yes 0.3V does make a difference to the components that rely on a 3.3V feed, however if the DSP is fried you are not going to see normal functionality or be able to diagnose further.
Posted on Sep 05, 2007
4 Suggested Answers
Rifaa
  • 99 Answers
SOURCE: Kenwood KRF 7775D not working with Digital Inputs
First of all my nick is Rifaa.
Secondly do you still have the amp
Posted on Sep 08, 2009
SOURCE: Need Experts Help!!
My receiver is experiencing the same issue now. I was thinking it was an amplifier output stage going out. I only took the hood off and measured some typical voltage areas, nothing too in depth while on the living room floor. What was your conclusion? I'd much rather fix mine than buy a new one.
Posted on Jul 06, 2010
Testimonial: "I am not here to help but to find a solution for my problem. I did not get any help here but however I already fixed mine. You can find me here http://forum.allaboutcircuits.com/index.php I only help here not any where else."
SOURCE: The DTS and DSP selections on my Pioneer HTZ-55DV
Try a factory reset[don't ask me how].Your processor stopped working properly...
Ask on producer's site for help and support.
Maybe you need to flash it.....
M
Posted on Jan 04, 2011
I have a kenwood Auto video surround receiver DR / 409 how to reset it
PDF]KRF-V8030D VR-409 - Kenwood
manual.kenwood.com/files/B60-4593-00.pdf
VR-409. INSTRUCTION MANUAL. KENWOOD CORPORATION. B60-4593-00 (EN) ...on the country and sales area. AUDIO VIDEO SURROUND RECEIVER ...
Kenwood VR-409 Manuals
www.manualslib.com > Brands > Kenwood Manuals > Stereo Receiver
View online or download Kenwood VR-409 Instruction Manual. ... Kenwood Instruction Manual Audio Video Surround Receiver KRF-V8030D VR-409.
Kenwood VR-409 Receiver Repair Questions, Solutions ...
www.fixya.com > Forum > Audio & Video Receivers > Kenwood
Recent Kenwood VR-409 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
Kenwood VR-409 PDF Owner's Manual Download & Preview
www.manualguru.com > Kenwood Manuals > VR-409
Feb 03, 2016 | Kenwood Audio Players & Recorders
My ken wood krf v5050d automatically goes back to standby what is the cause
hello! i need help with this, i have the same amp Kenwood KRF-V5050D it seems that it had a short circuit on the speaker terminals, close to the 2 12v relays wich are close to each other and the 2 transistors kia 7812 and kia 7912 was turned black, i have replaced them, and i have disconnect the 2 big IC but the amp still does go in the protection mode, but when i disconnect the 2 transistors kia 7812 and kia 7912 the amp does stay on. i have checked almost everything and it seemed to be good. i have checked every transistor and replaced some capacitors, but i have not replaced the 4 big capacitors, with all the 0.22j resistors and all the terminal relays and the 2 big ic disconnected the amp still goes on protection mode. i had this amp returned from ebay and the buyer is waiting for it to be repaired, i would aprecciate any help.
ujka.pjetracaj@hotmail.com
Kind Regards.
Oct 07, 2013 | Kenwood Rc-r0511 Home Theater Receiver...
I NEED A manual for a krf v5200d
  • Hope this helps.
Nov 02, 2011 | Kenwood KRF-V5060D Receiver
Hi, I have a KRF-4060D receiver and my problem is, that however the receiver is set to auto detecting, when I start a dts movie, the receiver does not recognize it as a a dts signal. could you please...
What DOES it detect instead - analog or Dolby Digital? If the former, the digital bitstream is not being seen at all - check the digital audio-bearing cabling.
If the latter ---
As dangerously loud undecoded digital bitstream [hash] "noise will be produced when a DTS source is played by selecting the analog input", the DTS soundtrack is not necessarily the default for a movie soundtrack and may need to be manually selected under the movie's own Audio Setup menus.
Jul 11, 2011 | Kenwood KRF-V4060D Receiver
I have a kenwod krf-v5050d amp (old I know). I have my blu ray hooked up via an optical cable however I can not get any sound through the speakers from it. I know it shouldnt be the speakers or the amp...
xjackdeth,
All systems with multiple audio/video inputs for each connection must be told what connection you want it to play. Most likely your selected choice of input is set to an input other than digital. I included a link to download the manual for your Kenwood model; see page 9 for "Input mode settings".
First use the input selector knob to select the input you are using for the blue ray player, then press the input mode button to select digital auto; the Kenwood should take a few seconds to switch over and then you will be in business.
http://audio.manualsonline.com/manuals/mfg/kenwood/krf-v5050d.html
-Chris
Jan 09, 2011 | Kenwood Unity System
Kenwood krf-x9995d surround issue
It's likely the power amp is faulty. However if you can't get in touch with Kenwood, then take it to another repair shop or go back to the other and tell them you can't get in touch with Kenwood and could they have a look at it anyway.
May 27, 2017 | Kenwood Audio Players & Recorders
Feb 27, 2009 | Kenwood DVT-6200 System
KRF-5030D i stand by mode
Does it go into standby when it's in another mode like : Cd or Video 1 or tape?
When you state that you checked the power amp IC's , how so did you do this?
Thanks n' let me know.
Feb 08, 2008 | Kenwood KRF-V5060D Receiver
Need Experts Help!!
Sep 04, 2007 | Audio Players & Recorders
142 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
