Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
D-link DI-624 wireless router connectivity problems (DNS suffix)
I just recently moved into my house at college and got time warner high speed internet/cable. I have had a D-link DI-624 wireless router that worked all last year but now is not able to give a DNS suffix to any computer that is hooked up to it. When the cable modem is directly hooked up to my computer the internet works fine. but when i try to route the signal through my router i get a valid ip address but no dns suffix. i reconfigured my router as well as restarted both the cable modem and router so many times I am sick. Any help at all would be greatly appreciated.
  • 2 more comments
  • France Lam Apr 30, 2008
    same exact problem. =(
    same problem.
  • s_rmfrances Jul 19, 2008
    Same problem. The DI-624 worked fine with Comcast but won't with Time Warner.
  • wagneraraujo Aug 13, 2008
    I'm not using the same ISP but I'm experiencing the same exact problem
    Genius:
  • 1,139 Answers
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Posted on Sep 04, 2007
SOURCE:
I dont know how to connect my wireless router
Download software and manuals from here:
http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
(http://www.dlink.com/images/support/common/download-now.jpg)
Jul 28, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
May 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Stop neigbour from using my network. Speed has become slow
Password protect your connection, if you are using Internet sharing option, limit the number of connections to 2 (one for you and the other for your neighbor no. 1)
Dec 17, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
CHEC
do a hard reset on your router, and try again. After the hard reset plug your modem into the router but disconnect the power and reconnect the power after 10seconds. Other than that, Dlink tech support should be able to help you solve the problem.
Dec 29, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
1,152 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
